I installed a Skip Shift Eliminator (plug in at the transmission) about a month ago. Until recently it worked just fine and not having to deal with the stupid 1st to 4th was all good. Then last week while pulling into traffic the dreaded 1st to 4th occurred. I thought maybe I simply missed the shift but it's happened a few more times...but not all the time. I've tested and about 2 out of every 6 times at low RPM acceleration it happens. No check engine lights. Has anyone else experienced this issue? Should I simply by a different SSE?
I had the exact same thing happen to me... your CAGS eliminator is likely bad. Just install a new one and I bet your problems disappear, or at least it solved my problem.
Are you sure you are not plugging it into the wrong thing. I am not sure what Skip Shift you are using but most of them are not inline meaning that you unplug the harness. The Skip Shift goes into the harness to just match the reistance of the solenoid so it does not set a CEL. There is absolutely nothing plugged into the solenoid for the skip shift on the transmission for it to work. It would have to have power in order to engage so you must not have plugged your module into the skip shift solenoid. They are on the Drivers side of the transmission.
If the eliminator is bad, it will set off the check engine light, but since it makes you unplug the harness to CAGS, it cannot make it shift when plugged in. If you plugged in a CAGS eliminator and your car is still going 1-4 it is not plugged into the CAGS.
Is it possible you installed the eliminator on the reverse lockout instead of the skip shift?
Well, I confirmed my skip shift is present in the car. I have an eliminator and will install it tomorrow. With regards to them going bad, yes they can. The eliminators are simply a resistor across two leads that fake out the controller into thinking the solenoid is still there. If it is of the style that plugs into the chassis harness then into the trans, a failure of the resistor (and it does happen) COULD cause an activation of the solenoid if the wiring somehow maintains continuity around the resistor. Or maybe the wiring melted on the exhaust. Who knows. A replacement unit is cheap and will likely solve the problem.
One I saw that failed was a 24 Ω resistor that was only 1/2 watt (!), at 13.7 V is more than 1/2 amp or almost 8 watts! A better value is 2.2K Ω which will only draw 6 mA.
With a C6 and it's dedicated skip-shift fuse, I prefer a CAGS LED fuse or a CAGS resistor. For my 2nd gen CTS-V (with a fuse shared with the reverse lockout solenoid), I made a custom cable (using delphi connectors from mouser.com) that plugs into both the factory harness and the solenoid, that way I didn't have to worry about dirt or water getting into anything. I used a 20K Ω (in series with the 120 Ω solenoid).
If you look further down on your link, you will find a section about the CAGS LED fuse, which uses the Littlefuse SmartGlow fuse. I bought a couple of those fuses, and used my dremmel tool to break the fuse element. Then, I plugged my modified fuse into the fuse box. Done. Now, I have no skip shift, and no skip indicator message on the dash either. If I open the fuse box when the car is running, the LED on my modified fuse can be seen illuminated. The skip shift circuit is protected, because, after all, the fuse is blown. I am very satisfied with this solution.
