Fuse Help
Old Nov 3, 2021 | 09:59 PM
ABern310's Avatar
ABern310
Default Fuse Help
Input needed:
Chasing down a voltage issue, pulled the alternator for replacement and noticed that the horn isn’t working. I can hear a click from the fuse box when I press the horn but no horn. Checked and swapped relays and fuses for the horn but still nothing. Any ideas as what to check next. Also, might be dumb for assuming that the horn would work with the alternator out of the car and maybe that’s my issue? Just got the car a few days and never have heard the horn
Old Nov 5, 2021 | 06:57 AM
4SUMERZ's Avatar
4SUMERZ
Have you checked the connector at the horn unit itself? That would be my first course of action. It appears that it is getting the signal to make it work. Horn is in the passeger side.
Good Luck
