Checking compression
Old Nov 7, 2021 | 08:15 PM
Bob's Red Corvette's Avatar
Bob's Red Corvette
Default Checking compression
Is there any way to hook up a starter button through the crank rely to turn the engine over for compression test? This is for GUD TWN needs help (2005 Z51 corvette).
Thanks!
Bob
Old Nov 8, 2021 | 10:25 AM
She_Thicc's Avatar
She_Thicc
Banned Scam/Spammer
I wonder if you could use the trick where you hold the gas pedal to the floor and hit the starter button. Supposed to turn over but not start.
Old Nov 8, 2021 | 05:25 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Yes, a "Clear Flood Crank" requires nothing but putting the gas pedal to the floor and HOLDING it there while attempting to start the car...no need to mess with relays !!
Old Nov 9, 2021 | 10:24 AM
Bob's Red Corvette
Actually looking for a remote starter button to plug into the crank relay, but thanks guys for your suggestion. I had an article but forgot where I put it.
Old Nov 9, 2021 | 04:42 PM
davidfarmer's Avatar
davidfarmer
you can pull the cap off of the starter relay and mechanically engage it.
To Checking compression
