C6 second gear rough shifts
Old Nov 17, 2021 | 10:22 PM
MeanLs3's Avatar
MeanLs3
Default C6 second gear rough shifts
Hey corvetteforum, my 2012 c6 has a tick master cylinder and mcleod rxt clutch. The 1-2 shift always seems rough even when cruising, and at high rpms sometimes it wont even let me into second. 2-3 and 3-4 are always butter. After beating on the car, the 1-2 is significantly smoother for some reason. Car makes around 500wheel if that matters. I have bled the clutch numerous times. If anyone has any idea of why my car is blocking me out of the 1-2 shift at high rpms please chime in. Thanks!
Old Nov 18, 2021 | 12:29 AM
ETPhoneHome's Avatar
ETPhoneHome
how many miles on your car? i have had similar issues, maybe not as bad but i know the feel. might need a rebuild. i have heard that disabling the 1 to 4 skip shift helps but i dont know if thats ur prob or not
Old Nov 18, 2021 | 12:38 AM
MeanLs3's Avatar
MeanLs3
67,000 miles on the car. Could this be clutch/hydraulics related? The shop that installed the rxt didnt bleed the clutch properly so I have my doubts as to whether they measured the distance between the slave. Sometimes a shim is required and im not sure if my symptoms could be representative of a dragging clutch or not? I would think I would be having problems getting into gear in all gears if it was clutch however im no expert on the matter. Also skip shift is disabled on my car, I had it tuned out.
Old Nov 21, 2021 | 12:36 AM
ETPhoneHome
Ya i got 82k on mine. 1-2 is always rough until i get some heat in the trans. if your clutch was dragging i would assume your car would move when in gear even when your clutch was depressed fully. it sounds more like syncro wear. i have been debating on a rebuild for mine but i will prob wait till 100k when my diff needs a rebuild
Old Nov 21, 2021 | 08:39 PM
JetstreamGS's Avatar
JetstreamGS
Welcome to the club. I have under 10k on my car and second gear grinds. Synchronizer is shot.
To C6 second gear rough shifts
