C6 Gear Shift Linkage
With that being said, has anybody ever done this repair? How do you set the upper linkage onto the bracket to lock it in with the clip? It’s so hard to get it to set since the bracket is behind the shifter opening on the tunnel.
I did not remove the exhaust but I did loosen it so that I could move it to the side so I can make more room to work. Do I need to remove anything else that would let me set the upper linkage by the gear shifter?
Any help would greatly be appreciated!
Last edited by Strike; Nov 22, 2021 at 09:49 AM. Reason: https://cimg2.ibsrv.net/gimg/www.corvetteforum.com-vbulletin/2000x1504/d55e1816_9007_429b_a286_59e37ad7603b_17971e4d6e65bdb74
