Speedometer Not Working Help
Old Dec 9, 2021 | 09:00 AM
JayzBentC6's Avatar
JayzBentC6
Default Speedometer Not Working Help
So I have zero speedometer in my 08 base M6 car. It works fine if I use the Tech 2 via the cluster options. And all 4 wheel speed sensors are good. I used the Tech 2 to monitor the sensors and all show speed. What else could be the issue? Could it be the VSS on the top of the differential? Whoever owned the car prior had replaced the clutch. Wondering if they either forgot to plug it back in or it got damaged. From what I see in the schematics it appears to go straight into the ECM from the diff. But I also notice that in the radio schematics the drk/grn white wire runs from ECM through the radio to the gauges. I heard this can also be an issue. But if that was bad would the gauge work via the Tech 2? They put in an aftermarket radio reason I mentioned it. Just not sure what I should be checking other than those. If anyone can help it would be greatly appreciated. I need to get this car inspected and that’s my last hurdle.
Old Dec 9, 2021 | 11:08 AM
SixAddict's Avatar
SixAddict
Get a hold of Dano523 he is a forum member and very knowledgeable about the issues with our C6’s.
Old Dec 9, 2021 | 11:45 AM
JayzBentC6's Avatar
JayzBentC6
Yeah he is the master about this stuff for sure. I will do that thanks!
Old Dec 9, 2021 | 02:52 PM
SG4247's Avatar
SG4247
I put a new sensor in my diff on my 08, and my speedo issues have been solved.
Old Dec 9, 2021 | 03:04 PM
JayzBentC6's Avatar
JayzBentC6
Was you able to change that without removing anything? Problem I have is the prior owner put Z06 exhaust on here and it’s all welded from x-pipe to muffler. And I can’t get it out of the way unless I cut it. I can just barely get my hand on the sensor. I’m wonder if I can drop the cradle enough to get it out.
Old Dec 9, 2021 | 05:15 PM
Dano523's Avatar
Dano523
Put a tech II on the car, go to BCM data, and look at the speedo reading as you drive the car.
If the VSS is starting to go out, will not see a reading on the BCM data for vehicle speed until you get to about 10mph, then will do a major jump to correct mileage.
If no reading at all, check the VSS connector to make sure is not unplugged, or that you have a wiring problem.
as show above, it not hard to get to the VSS blindly, since you do have the room between the top of the dif and the bottom of the car.
If BCM is showing the correct mileage cleanly with no intial starting jumps, then problem is not the VSS, but in the IPC/its connector or wiring instead.
Old Dec 9, 2021 | 06:24 PM
JayzBentC6's Avatar
JayzBentC6
Thanks Dano! Also great talking to you. Much appreciated! I will report back with my findings.
Old Dec 10, 2021 | 05:20 PM
davidfarmer's Avatar
davidfarmer
BCM feeds the dash, something isn’t talking. Lots of wires (I got 12lbs of wiring out of my car)
To Speedometer Not Working Help
