Help: Water pump recommendation
Old Dec 10, 2021 | 04:26 PM
dondoucette's Avatar
dondoucette
Default Help: Water pump recommendation
Not trying to be cheap here but the Gates 45011 Water Pump is less than half the price of an OEM pump and since I’m doing such an extensive amount of work to my 07 saving a bit of $ here and there without sacrificing reliability is important. Any of you folks have any experience with Gates?
Old Dec 10, 2021 | 10:58 PM
Seein_red's Avatar
Seein_red
Veteran: Marine Corps
I bought the gates and standing it Side by side with the OEM I took off, you could see the quality machining of the parts in comparison to OEM. Night and day difference.
been on my ride for only 1k miles so far, so can’t comment to durability, but no issues as of yet.
My .02 cents..
Old Dec 10, 2021 | 11:45 PM
dondoucette
thank you sir. Anybody else?
My .02 cents..
Old Dec 11, 2021 | 12:38 AM
torquetube's Avatar
torquetube
Which was night and which was day?
Old Dec 11, 2021 | 05:10 PM
Seein_red's Avatar
Seein_red
What part of the below English didn’t you understand?
“quality machining of the parts in comparison to OEM“
Old Dec 11, 2021 | 10:32 PM
torquetube's Avatar
torquetube
I ask for clarification and you want to have a fight. Forget it.
Old Dec 12, 2021 | 09:22 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
I used the Gates and haven't had any issues, so far. I've only had it on for a thousand miles or so and one weekend at the track so it's not a lengthy history for me, either. It looks prettier than the OEM.
Old Dec 20, 2021 | 09:44 AM
d16dcoe45's Avatar
d16dcoe45
Agree with you 100%! What he wrote is as clear as mud.
Old Dec 20, 2021 | 12:06 PM
schizcat's Avatar
schizcat
Mine was replaced with OEM in 2008 (its an 05 that had 35-40K on it at the time). Now has 111k + with no issues. Ive seen a good number of people on here recommend Gates over the years. Haven't heard a bad thing about them.
Old Dec 22, 2021 | 08:56 AM
double06's Avatar
double06
One thing you might do is convert to a later water pump (2009+). It moves the outlet to the drivers side which does a couple of things - it moves the hot hose out from under the air intake, it makes it easier to work on front of the car like turning motor over by hand or removing a camshaft sensor, and to maybe pivot off the gates thing is the later OEM pumps seem to be more robust than the early versions. I also did a side- by-side comparison and it looks like they made the passages larger in 2009+. If you do this you need a new thermostat as they are different and a new upper hose.
Old Jan 22, 2023 | 02:40 AM
neelfryer's Avatar
neelfryer
just want to say - I love this forum - I am restoring a 63 SWC
I need the correct water pump
found this thread - it's a 340 HP car and late in the run - it's an August Birthday - vin 121314
I have sent Bill Mock an e-mail thru his site and will wait for him to get ne back - or call them in Monday
any opinions are welcome - thanks - John
To Help: Water pump recommendation
