I recently purchased a 2007 c6 corvette. It’s got a stage three texas speed cam I can share all the specs if needed , ported heads, fast lsxr intake manifold, catless headers. I noticed one of my spark plug wires wasn’t staying on the plug properly anymore so I figured I’d go ahead and replace those along with the plugs. Does anybody have any ideas on what spark plugs I should run? Thanks for the help!
I'd run the plugs GM recommends for the LS7/LS9 engines. You can get a different plug to work, but you won't get a better one. 41-104 from memory. If that's not it, your local parts guy can set you straight.
And welcome to the forum
Any idea what I should gap them at? Or should I leave them at the stock .04? Thanks!
I've never touched or even checked the gap. They arrive with a sleeve protecting the threads and electrode. If the box isn't beat all to hell, they're fine. I've run them in LS engines from 450 to well over 700hp. The only spark plug trouble I had in any of these engines happened when I tried the TR6 plugs that some on this site are enamored with. Won't be doing that again.
Even though I know the gap is likely close, I'm too **** (typical engineer, I guess) to not check them and make sure they are all precisely gapped. I recently found one of 6 plugs pretty far off coming out of the box when changing plugs in the wife's 2014 Charger 3.6 V6.
I'm surprised the LS9 plug wouldn't be one heat range colder than the one specified for the LS3. Pretty typical recommendation for FI.
For the record, I ran TR6 plugs in my Magnacharged 2002 Avalanche running 10 psi. Granted it was just a 5.3; they ran fine with never an issue. I have read others who also reported issues with them.
I do eyeball them pretty hard, but yeah, my eyeball's not quite that good. TR6's are the same heat range as the 41-104's. Yes, one heat range cooler than stock LS2/3. I ran some that did fine and then I had a set that were just bad. Pulled them out and checked everything I knew to check. No cracks, no obvious signs of anything amiss. Re-installed and they still ran like crap. They ran fine until the boost/rpm got up there a bit and then things went south. Changed back to AC plugs and all was good.
I'd use stock plugs on a stock engine. Once you turn the wick up with cam/heads or F/I, I feel better with a step colder plug. I ran two steps colder on a 660 rwhp Vette and the thing felt sluggish at low rpm around town. Replaced with the 41-104's and all was good.
If I was racing a whole lot, and timeslips really mattered, a cheaper plug like the TR6 might be a decent option if changing the plugs often made me more confident. Then there's the charging system problems that happen on some C6's when using TR6's. Don't really understand that, but there are too many happenings to ignore.
Thanks for the help! I think I’ll go get a set of the 41-104’s not sure what plugs the previous owner installed as the car was built by him, but I do have the service chamfering system issue on mine. So it’s very possible that’s what’s installed right now! Again thanks for the help! This was way more helpful than anything else I’ve been reading lol.
