Converter swap
Old Dec 31, 2021 | 02:06 AM
c5mtl's Avatar
c5mtl
Default Converter swap
Hello….my motor is out and I’m wondering if I cAn just pull the Torque tube off and change the converter with the transmission still bolted to cradle
Old Dec 31, 2021 | 01:57 PM
farmington's Avatar
farmington
I don’t see why you couldn’t.
Old Dec 31, 2021 | 02:15 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
You can't as I tried something very similar once and it didn't work. I ended up having to drop the cradle like usual.
From what I remember the problem was that after unbolting the torque tube from the transmission you need to separate those two parts, but due to the tight clearances I couldn't move the torque tube far enough forward to remove the converter from the transmission.
To Converter swap
