Biggest Tire Setup On A Base C6
Old Jan 11, 2022 | 12:35 PM
N8 Wavy's Avatar
N8 Wavy
Default Biggest Tire Setup On A Base C6
What’s the biggest tire I can run on a stock C6 base without messing with the nannies?
My current tire setup is:
Front - 245/40R18
Rear - 285/35R19
On Continental Extreme Sport’s
I want the rear to be at least 305/35R19 but I am unsure if this will cause problems with the nannies on a stock C6 base
Popular Reply
Jan 11, 2022, 08:22 PM
old motorhead's Avatar
old motorhead
A narrow body has 10" rear and 8.5" front width rims. Michelin says their 305/35 19 PS SS is fine on a 10" rim. I've run 305/30 19s on stock rears for years with no issues. No uneven tire wear either. Currently running 295/35 19 rear and 255/40 18 front Michelin PS4's. I have no problems with the nannies. 255 is the max width Michelin recommends on an 8.5" wide rim. Tirerack.com and other tire sites has this info available.
Old Jan 11, 2022 | 03:40 PM
farmington's Avatar
farmington
I put the 305’s on back of mine and had occasional active handling messages. Cleared but popped up once in a while. Put stock back and no problem. You would need to put taller front tires to keep it in sync.
Old Jan 11, 2022 | 04:25 PM
Dano523's Avatar
Dano523
Very easy, and use a tire calculator to do the OD sizer difference from the stock tires front to back (1.08"), the plug in the rear tire you want to run, and find a front tire that it's OD will give you close to the same 1.08" calculation.
Also, note that width needed for the rims, since installing a tire on a narrow rim that recommended, will cause the OD to be slightly larger, since the tire will balloon out of the rim. Hence your 305 on a stock rear rim, may end up with greater center contact patch than desired, and not give the best traction when its ballooned on a rim too narrow for it.
Old Jan 11, 2022 | 05:06 PM
N8 Wavy's Avatar
N8 Wavy
Whats the biggest tire in the rear that will fit the stock rear rims?
Old Jan 11, 2022 | 08:22 PM
old motorhead
Old Jan 11, 2022 | 08:37 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Originally Posted by farmington
I put the 305’s on back of mine and had occasional active handling messages. Cleared, but popped up once in a while.
..... You would need to put taller front tires to keep it in sync.
That's a fact ..
I put a set of tall 305/45 -17 drag radials on the rear of my GS ... I would sometimes get active handling messages until I installed slightly taller front tires.
Old Jan 12, 2022 | 10:03 AM
old motorhead
Originally Posted by Turbo6TA
That's a fact ..
Happens the other way around too. I tried to run 305/30 19's (shorter than stock rears) along with stock fronts. T/C would come on right after the 3/4 shift during a hard pull. Disconcerting best describes it. Changed to 265/35 18's on the front and all was good.
Old Jan 12, 2022 | 12:02 PM
N8 Wavy's Avatar
N8 Wavy
I’m going to give this a try,
295/35 19 rear & 255/40 18 in front on Michelin PS4’s. Has anyone else tried this setup & active handling or TC wasn’t affected?
Old Jan 12, 2022 | 03:06 PM
cjchiaf's Avatar
cjchiaf
I'm running the exact same tires as Old Motorhead on my 2011 base C6 A6 vert with no AH issues (and much more traction than the stock run flats). These tires are exactly as you describe in your last post: 295/35 19 rear and 255/40 18 front Michelin Pilot Sport S4. I got mine through Tire Rack. They're not cheap but I think you will be happy with them.
Old Jan 12, 2022 | 03:24 PM
cjchiaf's Avatar
cjchiaf
I neglected to mention that, if you are still running your original TPM sensors, now is the time to replace them with new AC Delco units (actually made by Schrader in the UK). If you need the correct P/N let me know and I will get it for you.
Old Jan 13, 2022 | 04:06 AM
N8 Wavy's Avatar
N8 Wavy
I’ll definitely be going with this tire setup once I’m due for them. I do enjoy the Continental Extreme Sport tires but the 4S’s are the ones I’ll be going with next!
Old Mar 24, 2022 | 05:12 PM
Tim90NOS's Avatar
Tim90NOS
can you post that p/n? Thanks!
Old Mar 24, 2022 | 07:49 PM
jonjoy's Avatar
jonjoy
I'm running 295/35 ZR19 and 255/40 ZR18 on BBS wheels not and issue.
Old Mar 24, 2022 | 08:40 PM
C6_Racer_X's Avatar
C6_Racer_X
Hope this helps.
I should probably read more than just the thread title.
Old Mar 25, 2022 | 01:21 AM
HOXXOH's Avatar
HOXXOH
Front - 245/40R18
Rear - 285/35R19
Define "biggest". Tread width? Overall height? With stock wheels?
For what purpose?
Old Mar 27, 2022 | 08:27 PM
N8 Wavy's Avatar
N8 Wavy
For what purpose?
I want to run 305’s in the rear but I’ve been told the traction system will act up
Old Mar 27, 2022 | 08:34 PM
LightningBrett's Avatar
LightningBrett
305-30s are fine, just pair them with 265-35s. TC issues when paired with stock 245s.
To Biggest Tire Setup On A Base C6
Old Mar 27, 2022 | 08:49 PM
N8 Wavy's Avatar
N8 Wavy
awesome thank you, will I have any issues of tires hitting the inner tire wells?
Old Mar 27, 2022 | 11:09 PM
LightningBrett
No you should not. I'm currently running 275s and 305s no rubbing.
Old Mar 28, 2022 | 08:10 PM
DSOMC6's Avatar
DSOMC6
I step-up to a stickier compound vs wider unless you dd the car a good distance.
My C6 gripped excellent on a toyo r888r in a 285mm at 620ft lbs tq.
My lowly LT1 Camaro wont hook for crap on a 305mm Nitto at only 420ft lbs tq.
If it was a dd or sees rain then Id probably mount Michelin's as well.
