05 starting issue and limp mood.
Old Jan 19, 2022 | 09:05 PM
curtisb23's Avatar
curtisb23
Default 05 starting issue and limp mood.
Hey guys I have a 05c6 and it having a starting issue when hot. I have hurd and read plenty of pins loose an burns up the starter stud broken relays are good. So the car will start fine when cold but it runs at like a limp mood but doesn't say anything. The oil switch was acting up and the car was displaying engine reduce but I fixed that and it's no longer displaying that. So after a few mins or so it runs perfectly fine. After hot it will not start what so ever. With hptuners I can see the ecu isn't getting any voltage but the fuse is good and has 12v. I took apart the fuse box and everything seemed good. I'm at a loose with this thing so I'm here begging for help lol.
Old Jan 21, 2022 | 02:38 PM
Charliemopic's Avatar
Charliemopic
Search that on yutube. Might find something.
Old Jan 21, 2022 | 03:45 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Is this a crank no start ???…what data PID does HP Tuners show telling you the ECM isn’t getting any voltage ??…what is its name ??
To 05 starting issue and limp mood.
