Dashboard fix mileage
Old Jan 22, 2022 | 05:33 PM
cenorete's Avatar
cenorete
Default Dashboard fix mileage
Hello everybody. my Corvette ruined the dash and I managed to buy another used one the problem is that my car has 52k miles and the dash I bought has only 41, does anyone know how I can adjust the mileage to the correct value?
thanks
Old Jan 23, 2022 | 10:46 AM
grinder11's Avatar
grinder11
thanks
Probably a dealer only fix. Hopefully, you or the dealer can still access the correct mileage on your original DIC, so it can be programmed to the "new" DIC. Reason I say dealer only is there are legal hoops to jump thru, or even more people would have low mile Vette's. Best of luck....
Old Jan 23, 2022 | 12:40 PM
cenorete's Avatar
cenorete
Thanks for the answer. I'm going to look for the dealer nearby to see what they can do to fix this. thank you
Old Jan 24, 2022 | 02:36 AM
Dano523's Avatar
Dano523
Dealer fix for the most part, and they just pull the actual mileage from the BCM/ECM, call up AC Delco to have them write a VCI mileage firmware file they pull down, to reflash the IPC to the correct mileage.
The glitch is finding a dealer to do the flash, since most only do the flash when they replace the ICP themselves.
If this turns out to be a bust with any local dealer/local Ac Delco speedo shop, then you can pull the actual mileage yourself with a Tech II, make sure not to move the car at that point, then pull the IPC off to send to a third party to flash it to the correct mileage, so the IPC matches the BCM/ECM mileage in the end.
To Dashboard fix mileage
