So my driver side door wont open from inside or out, the window is locked, the driver side power window doesnt work for either window, the passenger door is fine.
i opened the door from the pulley in the trunk, pushed the door lock latch in so it acted like the door was shut. i pushed on the door button from the outside and the latch came out. but when i close the door, the it doesnt do anything.
Sounds like a broken wire(s) in the door harness and/or bad grounds....
well i did just change the battery like 2 weeks ago, you think that it couldve loosened up? then how come everything else is fine. the car starts fine, the passenger door works.
Did you try switching the outside handle switches ? They are known to get dirty and you can take them apart and clean them.
If I understood you .... you said you locked door and it not closed. that the outside would open it. But with door closed and locked the outside Handle switch would not unlock it.
Did you try the inside handle when it would not unlock outside?
Its hard to try and make sense of it because it makes little to no sense to me lol, but
The button inside doesnt work like at all, if i push the actuator thing inside where it thinks the door is shut, and press the outside handle, it unlatches and opens like it should, but the inside does not when i push the actuator in. and yes i did switch out both outside handle switches, nothing.
and also, the unlock/lock switch and the windows dont work.
If not for the window not working, I would think the latch /lock to be the problem.
I had similar problem and fixed mine, but the windows. That is one on me;
so the window works only if i push the actuator in and the door is open. The door doesn’t close obviously Bc the the latch is already secured. So when i push the outside door opener and it unlatches and close the door, the power to the windows, and power locks are lost. And there’s no light working as far as night when u can see the buttons, nothing. Only when the door is open and the actuator latch is secured.
If I understand your issue things work with the door open and you manually close the door actuator. Shutting the door which is basically the same thing and nothing works. My suggestion would be to see if power is getting to the switch with the door open and again when closed. If no power with door closed it could be a chafed wire in the loom that goes from the door into the cabin of the car. Having door open may let the wire make a connection and closed not so much. Can’t rule out door actuator but it does not sound like that is the problem.
So to kind of help this out a little, the inside door release button still doesnt work when the door is open. the lights are on on the door when it is open, but when i push the actuator in and keep the door open, and when i push the inside release button, it does nothing. but when i push outside door release when the door is open, the latch comes out and then i can close my door like normal, but when i do, i lose power to the door.
