How bad is it?
Old Feb 5, 2022 | 05:26 PM
Snatchrick's Avatar
Snatchrick
Default How bad is it?
06 base here. Accidentally shorted my battery/terminals and now the car wont turn over. Has code b1235. Looked around the fuses and none were popped. How can i tell if the ecm is fried? Hp tuners still shows some inputs when trying to start and everything else still works just wont crank over with plenty volts. Car was running fine before this. Where should i start? Thanks fellas
Old Feb 5, 2022 | 09:11 PM
torquetube's Avatar
torquetube
Shorted or reversed? If shorted, what touched what?
Old Feb 5, 2022 | 09:14 PM
Snatchrick's Avatar
Snatchrick
Positive cable touched the battery terminal while the neg was still hooked up
Old Feb 6, 2022 | 01:21 AM
torquetube's Avatar
torquetube
The positive cable contacted the positive terminal and made a little spark? It shouldn't have smoked your electrical system. Make sure your terminals are snug. What was going on that required disconnecting the battery?
Old Feb 6, 2022 | 01:59 AM
Snatchrick's Avatar
Snatchrick
i was hard wiring in the trickle charger to the terminals
Old Feb 6, 2022 | 02:10 AM
Blackship's Avatar
Blackship
2025 C6 of the Year Finalist - Modified
Without any blaming (i did so worse...). This case explains the reason why "Black (ground/negative) first off and red (positive) first on"
Old Feb 6, 2022 | 02:54 AM
torquetube's Avatar
torquetube
Originally Posted by Blackship
Without any blaming (i did so worse...). This case explains the reason why "Red first off and last on"
Black off first and on last. You want the negative terminal disconnected before you put a metal wrench on the positive terminal. This prevents the wrench completing a circuit if it contacts the chassis. On a negative-grounded car of course.
Old Feb 6, 2022 | 03:19 AM
Blackship's Avatar
Blackship
You're right, i corrected. I'm very sorry for the writing inversion. Bad Saturday night after driving 11 hours...
Great thank's for immédiat slip correction !
Old Feb 6, 2022 | 12:36 PM
Snatchrick's Avatar
Snatchrick
Resolved!!! Moved the shifter out of and back into park and it fired right up lol sometimes i just cant even with this car....
Old Feb 6, 2022 | 12:37 PM
Blackship's Avatar
Blackship
Cheers !
To How bad is it?
