LS2 Oil Temp / Level sensor - Wiring Question
Is there an aftermarket or alternative factory-ish Oil Temp sensor that'll work with the factory LS2 wiring? I'll end up grounding the one wire for the oil level, but I'd like to keep the factory wiring readout for oil temp. I'd place something on the feed oil line to the oil coolers.
Maybe the LS1 oil temp sensor, that's a 2 wire IIRC.
Looking for ideas
