Bleeding manual clutch
Old Mar 2, 2022 | 05:24 PM
davidfarmer's Avatar
davidfarmer
Default Bleeding manual clutch
so after decades of avoiding this, I had a car come through that obviously needed a real clutch bleed. I tried from below, but no way my arm was going up. However, if you disconnect the sway bar mount, remove the front half of the underbelly panel bolts, you can lower the entire front crossmember about 3" and get to the bleeder from above.
Now that I've done it a few times, I can do it about 15minutes on the lift. Yes the ranger method generally helps, but if you need a real bleed, it's easier from above than below in my recent experience.
This particular car seems to be having heat issues, not that I've bleed it thoroughly with RBF600, I wrapped the line and put heat shielding on the top of the headers. There doesn't seem to be any mechanical issues (clutch or the hydraulic seals), the fluid just is boiling too quickly. Hopefully the heat abatement helps.
Old Mar 2, 2022 | 05:46 PM
davidfarmer
view from above with just dropping the cradle a few inches
Old Mar 4, 2022 | 09:26 AM
tommyc6z06's Avatar
tommyc6z06
2023 Corvette of the Year Finalist - Unmodified
2022 C6 of the Year Winner - Unmodified
great info, if ever I have to do this. Thanks!
...and if that happens, I presume there would be enough room to install at a remote bleeder.
Old Mar 4, 2022 | 08:43 PM
davidfarmer
I was afraid to try honestly, I think you should be able to line the new fitting up but it’s tight. I didn’t want to drop the entire thing if I couldn’t get the AN adapter lined up.
im still not sure why c6 seems to have more clutch fluid issues than the c5 did.
Old Mar 5, 2022 | 07:01 PM
marcoturbo's Avatar
marcoturbo
Where does the used liquid fall on ? Can you catch it easily without a mess ?
Old Mar 5, 2022 | 08:35 PM
davidfarmer
drain pan under the car. This is well rearward of the friction plates, so it will just run off. These are dedicated race cars in my shop, nobody cares about a little drip.
However.....if I wasn't on the clock I'm sure I could do it with a piece of tubing. Still a lot quicker that trying to get it from the bottom.
To Bleeding manual clutch
