Autoblip issue
I installed an autoblip on my 06 Z yesterday and the lights read out correctly. The status light is solid, the brake light comes on when pressing the brakes and the clutch light comes on when pressing the clutch. When I hit the brake and then the clutch while driving, the blip light comes on but the engine doesn’t rev. Any suggestions?
On a side note if you get this working and you throw an APP code the problem is likely to be a poor connection.
The U-connectors are not that reliable. I eventually made solder connections and it has worked perfectly since.
I like this device. I am not good at heel/toe shifting. On the track this device saves a lot of clutch wear.
Two other tips:
It is easy to contact the designer. He is a good guy and is helpful.
Remove the drivers seat. It makes it easier for the install.
Two other tips:
