Flex Fuel Injectors
Old Mar 16, 2022 | 12:23 PM
C7&7's Avatar
C7&7
Default Flex Fuel Injectors
What injectors / size are you LS3 guys running when doing flex fuel / E85 setups?
I am putting an LS3 in a '69 El Camino project and want to get the fuel system dialed in.
Old Mar 16, 2022 | 01:25 PM
whowon's Avatar
whowon
Fuel injector clinic 660cc. Should support 600whp on e85.
Old Mar 16, 2022 | 01:31 PM
C7&7's Avatar
C7&7
Thanks. You run these? With factory in tank pump? I am assuming no, and there is some secondary fuel system installed or a higher volume in tank?
Old Mar 16, 2022 | 03:39 PM
whowon's Avatar
whowon
Nope, still stock pump. My car makes a little over 500 wheel, and the injector duty cycle is still in the low 50%.
To Flex Fuel Injectors
