driver side engine harness routing
Old Mar 18, 2022 | 11:41 PM
rsb213's Avatar
rsb213
Default driver side engine harness routing
just dropped a new motor into my c6 today and want to make sure the engine harness on the driver side is positioned correctly. does anyone have photos or can describe where it sits, specifically on the driver side between the motor mount and rear of the block? I have it going between the motor mount and the block, and then as you get closer to the firewall its strapped to a bolt hole just below the headers. Just afraid that location may be too hot with longtubes, but if that's where it is from the factory it'll make me feel better.
