Flex fuel sensor placement
My issue is that I am at a complete loss on how to mount/install the DSX flex fuel sensor... Currently the car has AA stage 1 fuel system (return style) with the ECS bulk head on the tank, the (S) tube that came with the sensor is not going to fit anywhere so I removed the sensor from that however i cannot find a suitable location to insert this sensor. If I try to plumb it between the rail feed and fuel line it jams the stock fuel line up against the firewall.. I also tried to mount it on the stock fuel line in between the AA fuel lines and stock that pushed the AA lines at a horrible angle and i felt put a lot of stress on the sensor ends.. does any one have any pictures or advice on how they got this sensor in to not bind everything up?
I did it that way because:
1. if you put a flexfuel sensor in the A&A single stage kit, the split they put on the end of the hose is moved out of position and it kinks and looks all shoddy.
2. you want it to sense the content of the fuel even if the secondary pump isn't running, so you have to connect the stock and external supply and then go to the sensor, and this seemed like the best way to that and basically hide the sensor.
So, I had to buy:
2 90º EFI 3/8 fittings w/ 8 AN male
5 AN straight female hose ends
2 EFI 8AN connectors (I got the screw down type, not the plastic quick disconnects like the 90)
1 Tee
whatever you figure you'll need in 8 AN line
https://i.imgur.com/C2u4B9E.png
the AA kit is perfect when not installing a flex sensor however with the sensor I have to find another route..
