Pushrod length?
Old Mar 28, 2022 | 09:09 AM
rc51racer's Avatar
rc51racer
Default Pushrod length?
I’m measuring for pushrods for my 05 LS2 Corvette for the new heads.
Things I’ve changed….
Currently have cyl head and new gasket snug(not torqued) on engine.
-1.8 roller rockers from 1.7
-64 cc chambers from 65cc on the Gen X 225 heads.
-.040 Cometic head gasket
-228/232 112 LSA .600 cam
When I check intake rocker on base circle with pushrod measuring tool it’s 14.5 turns.
14.5 X .050 = .725 + 6.80 = 7.525 pushrod length.
Sound correct?
I got 1 1/8 turn to 22 lb ft torque for rocker bolt.
**FYI Trick Flow states 7.500 pushrods for their Gen X 225 LS2 top end kit with 1.7 roller rockers**
Old Mar 28, 2022 | 09:30 AM
Pb82 Ronin's Avatar
Pb82 Ronin
What lifters are you using?
Old Mar 28, 2022 | 09:47 AM
rc51racer's Avatar
rc51racer
Old LS2 lifters I made into solid lifters by taking apart and flipping plunger. Will be adding LS7 lifters for final build.
forgot to mention I got 1 1/8 turn to 22 lb ft torque for rocker bolt.
Old Mar 28, 2022 | 10:34 AM
torquetube's Avatar
torquetube
I would finish the motor, then measure with a length checker.
Old Mar 28, 2022 | 10:51 AM
rc51racer's Avatar
rc51racer
I was using a pushrod length check tool
Old Mar 28, 2022 | 11:47 AM
Pb82 Ronin's Avatar
Pb82 Ronin
LS7 lifters have .200 plunger travel. If TFS says run 7.5s and your measurements are giving you 7.525, you'll be fine with 7.5s.
Side note: I would use an old head gaskets if you have one and fully torque the head. Without the gasket crushed down to spec, your measurements will be off by that crush dimension.
Old Mar 28, 2022 | 03:30 PM
1Hotrodz's Avatar
1Hotrodz
What's your lifter pre-load? Did you add that in? And what is the crush height(torqued) of the new cometic gasket? You need to subtract that dimension.
Old Mar 28, 2022 | 04:45 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Yup ... and .200" is a lot of available travel .... Get the preload somewhere in the middle (.070" - .120") and you will be fine.
BTW ... Using 1.8 ratio rocker arms, this is what the bolt turns will get you for preload (starting at zero preload)
Old Mar 28, 2022 | 05:12 PM
Turbo6TA's Avatar
Turbo6TA
And, BTW, I am also using 1.8 ratio rocker arms and an aftermarket cam in my LS3 ... At .090" lifter preload, the valvetrain noise is very minimal.
Very quiet with the stock cam and 1.8 ratio rocker arms, but still pretty quiet after the aftermarket cam was installed.
Again, all you need is somewhere in the middle of zero and 200 thousands preload ... .090" worked good for me.
Old Mar 29, 2022 | 08:42 AM
rc51racer's Avatar
rc51racer
I do need to figure difference of crush height head gasket vs torqued.
I’m actually using the turn method to figure preload after finding 0 lash. The way I understand it that gets my lifter preload figured in without adding it in. I’m at 1 1/8 turn on rocker bolt after 0 lash. Correct?
Old Mar 29, 2022 | 09:09 AM
Pb82 Ronin's Avatar
Pb82 Ronin
They're pedestal rockers man. The torque spec is correct number of turns. Why make it hard on yourself? Torque your head down on an old gasket and do this:
1) Get the cam on the base circle
2) Install your PR length checker as collapsed as it will go (that you can still operate it)
3) TORQUE rocker bolt to desired TQ spec (22 ft lbs)
4) Adjust PR to zero lash (you may have to remove and retorque the bolt to accomplish this)
5) When you get zero lash with the rocker bolt at 22 ft lbs, measure your PR.
6) Add desired "lifter pre-load" to that length and order your PR's.
7) Open a beer and wait for FedEx to deliver your PRs.
Old Mar 29, 2022 | 04:36 PM
rc51racer's Avatar
rc51racer
Turbo6TA PM sent….
Old Mar 29, 2022 | 05:10 PM
Turbo6TA's Avatar
Turbo6TA
And for anyone else interested ...
Old Mar 29, 2022 | 05:14 PM
Turbo6TA's Avatar
Turbo6TA
And as far as to . "How Much Lifter Preload Does 1 Turn of the Rocker Arm Bolt Equal" .....
Old Mar 29, 2022 | 10:49 PM
rc51racer's Avatar
rc51racer
thanks!
that finally worked and made sense. I was trying to combine this method and the “turn” method that Richard Holder has a video on.
So what I need for PR length is 7.500
Old Mar 30, 2022 | 06:56 AM
Pb82 Ronin's Avatar
Pb82 Ronin
Originally Posted by rc51racer
thanks!
Anytime. Glad it helped.
To Pushrod length?
