misfire, hesitation, ???
Easy and may just be active handling kicking it since you have the car in all on Nanny mode.
So start with pushing the TC button three times with motor running, until you see "comp mode" come up in the DIC. This will allow the back end to step out farther, Yaw sensor to allow more side G force, until active handling does kick in to try to save the car.
If that does work to keep Active handling from kicking in too soon, but still fighting active handling, then there is the next level and that is to turn active handling completely off. To do this, press and hold the TC button down with the motor running for 5 second, until you see "all off" in the DIC.
But, before you turn active handling all the way off (only abs will still be one), keep in mind that if you lose the back end/control of the car, the back end can kick around to be the part of the car going down the road first (in a heart beat), and Active handling is not going to be on to save you. So unless you have the skill level to play tokyo drift in a HP sports car and keep it in check/understand that the rear end can snap hook around on you, car should be left with all nannies on for street use, comp mode used for road course use instead.
Hence most of these crashes, are caused by the rear end snap hooking, and active handling either off, or not fast enough to save the car isntead.
we have the Mag-ride with the Jim Mero upgrade. sent Jim a e-mail and asked if the Mag-ride could be suspect, and he told me the only thing would be TC on and it reducing timing ??
we ran the car with TC off and the Mag-ride set on 3, leaves the active handling on !!
I know, the whole Z06 with F55 should have been the give away from the start.
Here you go on your PTM/F55 settings, and what they do.
https://www.roadandtrack.com/new-car...-how-it-works/
we did not realize we had the PTM !!!! Maybe Jim Mero should have told us that ??? you are 1000% right on it's exactly what is happening !!! Thank You so much !!!
