C6 LS3 Auto Thermostat advice
Old Apr 7, 2022 | 03:58 PM
Cashmando's Avatar
Cashmando
Default C6 LS3 Auto Thermostat advice
I'd like to get input/advice on if I should change the stock Thermostat (195°?) to a lower temp Thermostat (160°?), and will this help performance in any way? If so, which one is the best, and where do buy it? Is it an easy DIY?
Thanks for your help!
Old Apr 7, 2022 | 07:10 PM
RedC6Adam's Avatar
RedC6Adam
Not a big job, it makes the coolant temp rise quicker. No special reason to do it, unless you’re just in that area while you’re doing something.
Old Apr 7, 2022 | 09:38 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Thermostat
FYI OEM thermostat is 186.
Old Apr 8, 2022 | 04:28 AM
TopLevel's Avatar
0TopLevel
Former Vendor
No sense honestly. The temp wont go below 180* with 160* t-stat anyways.
Old Apr 8, 2022 | 06:14 AM
Spaceme1117's Avatar
Spaceme1117
Unless this is an all-out race car, a 160 thermostat is pretty much useless.
Old Apr 8, 2022 | 08:00 AM
grinder11's Avatar
grinder11
If running the stock fan settings, this will only slightly delay the coolant temp rise, and you'll use more fuel until it gets to the same coolant temps you're seeing now. I've run a 160° stat for many years. However, I have changed the fan settings, and am running a DeWitts radiator. I'm going to swap out the 160° stat soon, to a 174° LPE stat. Why? Because I'm using a lot of fuel until the coolant gets up to operating temp. A thermostat controls only the minimum temps, not the maximum temps. I might run a degree, or two warmer, but I'll get there sooner, which I think is a good thing for the entire engine. My .02.......
Old Apr 8, 2022 | 04:02 PM
Cashmando's Avatar
Cashmando
Many thanks to all who commented...the only reason I asked is b/c a tuning shop suggested it...
Old Apr 8, 2022 | 09:50 PM
farmington's Avatar
farmington
Tuners like the 160 stat for drag racing where car is cooled between passes. Allows them to add more timing without detonation.
Old Apr 11, 2022 | 09:44 PM
CrvtBB's Avatar
CrvtBB
Veteran: Coast Guard
I was not leaning toward a 160 thermostat, but it comes with the Katech Stage II I had installed. I figured if the people that built championship racing engines for Corvette Racing decided it was a good thing, I wasn't going to question it. Whether it hurts or helps, I can't tell you - but I know my LS3 is a monster that drives better than stock with an extra 100 hp to the wheels.
Old Apr 13, 2022 | 09:15 AM
Dano523's Avatar
Dano523
The t stat will lower the engine temps about 10* when not on the motor crusing since it will start to open up at a lower temp, but when on the motor, temps are going to be back to normal higher temps isntead.
Hence to lower and hold the motor temp lower when on the throttle, really need to improve the radiator and fan system, and not just try to over clock the OEM fan to come on sooner to burn it and the PWM out instead. Hence even with the lower T stat in the car, by the third dyno pull if back to back in a few mins, the motor is already back to its normal higher working temps.
As for running a 160 T stat, not where you are going to be driving the car in close to freezing temps. The T start will start to open too low in temp, and it can freeze shock the motor parts (metal contracts when it gets cold, and one of the reason that you really don't want to get on the motor hard until the oil temp has come up to 175*).
To C6 LS3 Auto Thermostat advice
