Fuel pressure
Old Apr 19, 2022 | 08:21 AM
Mcrook87's Avatar
Mcrook87
7th Gear
Default Fuel pressure
Added a new walbro 450 fuel pump assembly couple weeks back the stock wasn't holding up to the hp rang I'm in but car ran good for little over 3 weeks made around 8 good passes at the track the car was holding 63 psi fuel pressure at idle an bounced between 50-55 during a pull now all of a sudden I have no fuel pressure and my fuel is pumping into the passenger side an not to the engine I pulled the new fuel pump an bench tested just the pump an was making 90-100 psi no problem also check voltage at the head an it was good has anybody had this problem
