Help traction control problem
Old May 2, 2022 | 02:45 PM
Gosuit's Avatar
Gosuit
2nd Gear
Default Help traction control problem
Hey everyone,
New here and just got a 07 corvette and having a problem.
​​​​​​When I do a complete stop, starting from zero I hear a grinding noise and traction control active light pop on and off. But I'm basically running at 3 mph I am not spinning or anything. It's only doing this from zero..
Thanks all
Sorry for any grammatical errors, it's not my native language
Old May 3, 2022 | 07:18 AM
Gosuit's Avatar
Gosuit
2nd Gear
Bump
Old May 3, 2022 | 11:12 PM
vetteJPJ's Avatar
vetteJPJ
Sorry I can't help. But I'm sure someone with a similar issue might chime in. Good Luck with your new purchase.
Old May 4, 2022 | 09:22 AM
ThisisLivin's Avatar
ThisisLivin
Sounds like a bad wheel speed sensor, or bad hub bearing. That's my first indication I need to replace a hub bearing is when the anti-lock acts up. Have you checked for codes?
To Help traction control problem
