Cylinder Wall Scratches (please help)
Worst case: pull it down again and repair the additional damage done in the meantime.
You already have it halfway apart with the heads off anyway.
In context, bearings and gaskets are cheap.
Give the cylinders a really quick hone, replace the rings, clean all the metal debris out of the block...
Do it once the right way, good to go.
. I use no oil, and the car runs like a scalded dog!! Actually, it runs so good, I've seriously gained respect for Lear, the GM vendor who built the seats, because the seat backs haven't broken.....yet. I am sans cats, so I'd see smoke if there was much oil getting past the rings. If you're going for a world's record speed in the 1/4 mile, you may want to freshen it up. If you aren't using oil (if you are still running cats, they will hide a lot of oil smoke.), and it's a street/strip car, I'd run it. My .02......EDIT: Get a good, VERY GOOD, rare earth magnetic drain plug. It will help cleanse the internals as you drive. That's how I found out my Comp trunnions were junk. That and the great forum members here. Also, have a good look at your oil pump. It may be all scored up even worse than the cylinders....
