Fan not working and plug looks mint
Old May 6, 2022 | 01:44 PM
Chief Sauce's Avatar
Chief Sauce
Default Fan not working and plug looks mint
I never seem to hear the fan come on and in traffic I can be up to 220-230ish which seems hot. Checked the upper fan plug and it looks absolutely mint. What's the best process to tackle this?
Later today i am going to start the car and throw the AC on too, see if the fan comes on
Old May 6, 2022 | 02:43 PM
PDsVettes's Avatar
PDsVettes
Here's the wiring diagram for the cooling circuit.
File Type: pdf
Old May 6, 2022 | 06:57 PM
gdmoore01's Avatar
gdmoore01
You really need to pull the plug apart to validate the 3 connectors are in good shape on both ends of the receptacle. If your A/C system is fully charged and working, the fan should automatically come on with the A/C engaged.
GD
Old May 6, 2022 | 09:26 PM
Chief Sauce
Checked the fuse and appears to be ok, turning on the AC did nothing for the fan. Guess I’ll have to get the multi meter out
Old May 6, 2022 | 11:03 PM
HOXXOH's Avatar
HOXXOH
Although the plug internals are the usual problem, I've had one occasion where the fault was farther down toward the fan module itself. My first fix was a GM replacement connector. I don't suggest that, because the wire gauge is smaller (12 vs 10 IIRC) and it burnt itself up in about a year.
Old May 7, 2022 | 07:01 AM
Chief Sauce
replacement connector now is actually smaller gauge than original?
Old May 7, 2022 | 10:48 AM
rsb213's Avatar
rsb213
i bought a large 3 wire connector used for car audio projects to connect them together. i know that’s not the suspected issue here though.
To Fan not working and plug looks mint
