P1482 Cooling fan speed output circuit
Old May 18, 2022 | 05:44 PM
John Row's Avatar
John Row
Default P1482 Cooling fan speed output circuit
Can anyone interpret the above code?
I had the alternator go bad (voltage all over the place, 10.5 to 13.8). It caused several codes to be thrown. After disconnecting the negative terminal and replacing the alternator, all the codes cleared except the above. (and an emissions issue, hopefully that clears with a few more miles).
Any suggestions would be appreciated.
