Royal Purple diff gear oil
Old May 30, 2022 | 05:32 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Default Royal Purple diff gear oil
I just drained my diff and refilled it with 2 quarts of Royal Purple gear lube with friction additive.
A club member said that was a major mistake! He said that I should have used GMs gear lube and a bottle of their limited slip additive.
Have I screwed up?
Tom
Old May 30, 2022 | 06:08 PM
3X2's Avatar
3X2
You'll be fine. I've used royal purple, mobil 1, and redline with no problems in dozens of corvettes.
Old May 30, 2022 | 07:35 PM
Dano523's Avatar
Dano523
Have I screwed up?
Tom
Yes , since the lube you used is too slick, will lower the break away value of the LDS clutchs that should be at 100lbs if you use the correct lube (do not add more limited slip additive, since it already in the lube),
to something way lower, and will end up with peg leg burn outs. Also, since the clutch packs are not locking up correctly to 100ftlbs, just means that you are burning out the clutch packs a lot faster since they are slipping more instead.
Last I check, someone else to rebuild a diff to replace the clutch packs is a few thousands, so would eat the cost of the RP, and get the correct fluid in play now. Also, once you do have the correct fluid in play, large parking lot to do tight slow figure 8's both ways, to flush the RP out of the discs, and get the correct fluid back in them.
Same with using the correct trans fluid, since the synchro's have clutch disc discs as well, and too slick of a fluid will end up with them not working correctly and burning them up quickly too.
Old May 30, 2022 | 11:03 PM
3X2's Avatar
3X2
Sorry to disagree, but synthetic gear oil will not cause any clutch problems in the diff. Actually the additive causes the clutches to slip. Slip=heat=wear=more slip= more wear. That is why the chatter when turning goes away when the additive is used, the clutch plates are sliding easier on themselves. Our preference is mobil 1 75w-90 delvac without the additive. For manual transmissions, we use pennzoil syncromesh
Old Jun 1, 2022 | 11:59 AM
TCW's Avatar
TCW
Great write up Dano! But I was under the impression that the Dexron was for 2008 and above. The 05-07 used the synthetic gear lube from the factory.
From the 2006 manual:"SAE 75W-90 Synthetic Axle Lubricant (GM Part No. U.S. 12378261, in Canada 10953455) meeting GM Specification 9986115. With a complete drain and refill add 4 ounces (118 ml) of Limited-Slip Axle Lubricant Additiv(GM Part No. U.S. 10523Canada 992694) where required."
The reason I selected Royal Purple was because it was a synthetic and had the limited slip additive already added.
Tom
Old Jun 4, 2022 | 05:33 AM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
Don't ya just love it when people answer their own question?
Old Jun 4, 2022 | 05:37 AM
ls1121's Avatar
ls1121
I remember back when my rear car making a terrible noise from the back end, Loud clunking. Posting and reading looked like I needed some work done. Someone suggested that I replace the oil in the rear end before spending all that money. It has been years and the noise has still not returned.
Old Jun 4, 2022 | 09:06 AM
TCW's Avatar
TCW
Actually, the question was if Royal Purple was a bad choice!
Tom
Old Jun 4, 2022 | 09:47 AM
ls1121's Avatar
ls1121
Tom
And the answer was yes.
Old Jun 4, 2022 | 12:43 PM
Dano523's Avatar
Dano523
The old diff fluid in the 05-07 was causing clutch pack chatter problems, and was changed out to the Dexron as part of a TSB in the early models.
As the RP in the diff now, easy enough to break out a torque wrench with trans in park/gear, only one side jacked up (other wheel down chocked), and put a torque wrench on the axle nut to see if that side clutch pack slips/axle turns with the wheel up in the air before you hit 100ftlbs.
Note, remember to leave the parking brake off.
Old Jun 5, 2022 | 04:00 PM
TCW's Avatar
TCW
Originally Posted by Dano523
.....put a torque wrench on the axle nut to see if that side clutch pack slips/axle turns with the wheel up in the air before you hit 100ftlbs.
I hit 91 ftlbs on my torque wench. I have the GM gear oil on order.
On another note, when I did the figure 8s, the diff sounded like a coffee grinder!! (Royal Purple) I'll post the difference with the GM stuff when I get it.
Tom
Old Jun 8, 2022 | 10:03 AM
jonjoy's Avatar
jonjoy
Considering you added the little bottle of additive yes you screwed up. They all have that in them now. And the guy of which you speak, is an idiot
Old Jun 8, 2022 | 10:05 AM
jonjoy's Avatar
jonjoy
And don't listen to Dano he's clueless too like your friend. Too slick, what an .......
Old Jun 8, 2022 | 11:56 AM
TCW's Avatar
TCW
HUH? Where did you read that? I didn't add anything. Like Dexron, Royal Purple already has the limited slip additive in it.
Tom
Old Jun 8, 2022 | 01:25 PM
Aardwolf's Avatar
Aardwolf
Thanks for checking the breakaway torque. The 9 lbs low could be your wrench or even be normal since there wasn't a before reading taken. I've used most of the brands over the decades and haven't found any difference, YMMV of course.
Old Jun 8, 2022 | 03:32 PM
TCW's Avatar
TCW
I just drained out the Royal Purple and put in 2 quarts of Dexron 88862624. After I do the figure 8s, I'll retest the breakaway torque.
Probably can't do the figure 8's until next Sunday morning when the Mall is closed.
Tom
Old Jun 8, 2022 | 03:53 PM
Aardwolf's Avatar
Aardwolf
If you have a chainsaw the still somewhat fresh diff oil makes a passable bar and chain lube.
Old Jun 9, 2022 | 03:01 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
I did my diff with Royal Purple about 10k ago. I'm starting to hear chatter. Going to replace it.
Old Jun 9, 2022 | 07:02 PM
Jeff T.'s Avatar
Jeff T.
Question for Dano523. I have 2 new bottles of Mobil 1 75W90 on the shelf with their limited slip friction modifier. Would that be an acceptable alternative to the Dexron??
To Royal Purple diff gear oil
