SacCity Big3
Old Jun 3, 2022 | 08:45 AM
mcm95403's Avatar
mcm95403
Default SacCity Big3
This is the 3rd car I've done this kit, previously did it on my 07 and also my Nassau blue 99. Each time, I've seen .2 to .3 volts more charging output and this time I notice that the car is just running smoother - and I mean it's like butter!
The install is simple and I have to say, the instructions are the best of any aftermarket item I've ever seen.
https://www.saccitycorvette.com/C6-Big3.html
Definitely worth it!
Old Jun 3, 2022 | 06:50 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Hi,
Thank you so much for the nice review and your business! We really appreciate it!
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Jun 10, 2022 | 10:44 AM
jonjoy's Avatar
jonjoy
Yes it is a major improvement!
Old Sep 12, 2022 | 02:39 AM
SacCityCorvette
Supporting Vendor
Thank you jonjoy!
Old Sep 12, 2022 | 04:48 PM
jonjoy's Avatar
jonjoy
Everything I have used of yours, first of all worked . But it also worked exceptionally well and was well thought out
Old Sep 12, 2022 | 07:32 PM
SacCityCorvette
Supporting Vendor
Thank you for the nice report on our products! We really appreciate it!
Christian
Old Sep 17, 2022 | 01:09 AM
Nosferatu333's Avatar
Nosferatu333
Got anything for the c6 zr1?
btw. What color is the car on your website? Looks killer.
Old Sep 17, 2022 | 07:20 PM
SacCityCorvette
Supporting Vendor
Hi Nosferatu333,
Sorry we don't have a Big 3 for the ZR1, only for the Standard C6, GS and Zo6.
Haven't gotten our hands on a ZR1 to prototype one on.
Not sure of the name of the color of that ZR1 on our site. It was just such an awesome looking ZR1 picture
that we had to put it on our site for everyone to see.
Thank you,
Christian
Old Sep 17, 2022 | 07:31 PM
Nosferatu333
I’m in Vacaville. I’ll let you get your hands on mine if you want! Sac is all on 35 minutes from me. 25 if I take the zr1!…. Let me know.
Jorge
Old Sep 18, 2022 | 09:46 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
I like it too only some feed back to share. The wire fuse black box with sticky tape recommendation to the fuse box makes it difficult to remove or install a battery.
Old Sep 19, 2022 | 11:22 PM
SacCityCorvette
Supporting Vendor
Hi,
Thanks for the input. We have sold a few hundred C6 Big 3's and you are the first to mention that it interferes with battery removal and install.
We even have one on our C6 and the battery clears. Maybe some batteries might be a little bigger then others.
If your your battery doesn't have quit enough clearance I would recommend that you and anyone else pop the cover on the fuse box off.
That will give you a little more clearance that might be just what you need.
Thank you,
Christian
Old Sep 20, 2022 | 12:03 AM
SacCityCorvette
Supporting Vendor
Jorge
Hi Jorge,
I PM'd you!
Old Sep 20, 2022 | 08:12 PM
old motorhead's Avatar
old motorhead
If all of my connections are clean and tight, is there still an improvement? I have an aftermarket head unit pushing stock speakers. No add on amp. Shouldn't be much over stock as far as load goes. I do have an underdriven crank pulley. Idle is turned up due to bigger camshaft.
Old Sep 20, 2022 | 10:40 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Originally Posted by SacCityCorvette
Hi,
Thank you,
Christian
Yes SIr that is what i had to do for a quick fix was remove the line fuse cover for a quick second.
It clears it but like i said just some feed back you have to swing in an optima in and out at an angle and not a straight drop in hope you don't bump it or drop it on it..
Old Sep 21, 2022 | 06:28 AM
jonjoy's Avatar
jonjoy
If you trim the cover slightly you can rotate that spade connector a little and then wa-la just like stock
To SacCity Big3
