Hi Everyone, I have a 2011 Grand Sport and want to replace the rear tires on my stock wheels, leaving the fronts with the stock size. Seems like the 345/30R19 size is not readily available yet there's plenty in the 355/R3019 size. Has anyone run the stock 275/35R18 front tires with 355/30R19 rear tires and have not run into AH/TC problems? I appreciate all your responses. Larry
a 345/30/19 and a 355/30/19 actually both work out to be 27 inches so you should be fine.
If you are referring to the Kumhos, i ran that size combo with no warning lights. The rears did rub on fiberglass rear fenders causing slight damage. Make sure your car isn't slammed to the ground.
If you have mounted 355/30R19 tires on stock Grand Sport, Z06 or ZR1 wheels, not lowered, did the 355 tire stick out past the rear flared fenders at the top? I'm currently looking at the Michelin Pilot Sport 4S.
These are flush with the fenders. They rubbed over bumps
