LS2 Ticking at 2000 RPMs
Car was stock when I bought it last fall. Since then I installed LG Motorsports longtube headers, x-pipe, and NPP mufflers over the winter. I do not recall noticing a difference in ticking after that.
After the harmonic balancer fail, I installed a TSP 228/232 .600" cam, TSP hardened pushrods (stock length), TSP dual valve springs, and an ATI Superdamper. I did not change lifters or rockers. I installed a new oil pump o-ring when I had it apart. If I was getting the oil aerated I've read that I would be able to tell by pulling the dipstick after running it and seeing bubbles, I haven't seen that at all. Oil pressure is 40psi cold at idle, 30 when hot. Rises as it should with RPMs. I have measured and remeasured pushrod length multiple times and keep coming up with 7.400 as the correct length. I've pulled the valve cover multiple times to check the rockers, springs, pushrods, etc.
Everything in the top end is getting oil (ran it quickly with the valve covers off). Changed the oil since the cam swap and found no metal in it. I also ran Seafoam and ATF in the oil to see if the lifters needed to be cleaned before the oil change. I put 5w40 oil it to see if it changed anything, did not. I've listened to the car with a stethoscope and can't pinpoint exactly where the ticking is coming from except that its not the timing chain and I can hear it most when sticking it on the valve covers. I did hear it slightly more at the back of the passenger side valve cover but barely different. It runs great, I'm doing the tuning and have not see anything in the logs to indicate an issue.
Any input would be helpful. I'm debating just buying some LS7 lifters and bronze trunnion upgrades.
Regardless, I decided to just go ahead with upgrading the lifters and rockers. I was getting nervous that I could have a lifter (or more) going bad and didn't want to wipe out my new cam, and it would be a good reliability upgrade if there wasn't an issue.
I've already got the motor going back together. Been working on it this week after work. Luckily the cam is fine and the original lifters look ok (no wear on the wheels). Got the heads back on and torqued down last night and should be finished tonight. I still need to press in the bronze rocker trunnion bushings.
At least I'll have the knowledge that everything on the top end is ok and won't need to worry about it anymore. Plus the assurance that I know I don't have a failing lifter and the rocker bearings won't fail.
https://www.summitracing.com/parts/SUM-HT217-16
Summit lists them as LS7 lifters, I assume they mean "LS7 style" when they say that. From what I remember reading is they are basically an LS7 lifter with better valving to prevent pump up at high RPM. I'm certainly no expert though, just going off what I found with a google search.
edit: I just found on Morel's site the recommended preload is .045-.050 for aluminum head and block.
