Remove C6 driver seat NEED HELP Please
Old Aug 5, 2022 | 07:56 PM
Travis1103's Avatar
Travis1103
Cruising
Default Remove C6 driver seat NEED HELP Please
The driver seat on my C6 is stuck all the way back n I can’t move it. It’s power n I have looked everywhere to find help someone please help me. I can get to the front two bolts but not the back have looked at the front under the seat but can’t figure it out. I know it’s probably the power supply under the seat and I got the replacement cord but can’t remove the seat to fix. All fuses are good and also the air bag light has started coming on for that side. Any video or some help please fellow C6 owners
Old Aug 5, 2022 | 08:57 PM
kanvasman's Avatar
kanvasman
Make sure the plug is secure. There was an issue with the plug coming loose and triggering the airbag light. Maybe it just wiggled a little and you are lucky.
Old Aug 5, 2022 | 09:28 PM
Travis1103's Avatar
Travis1103
Cruising
Default Thanks
I tried it n also sprayed with contact cleaner no luck can’t move it
Old Aug 6, 2022 | 07:33 AM
Dads2kconvertible's Avatar
Dads2kconvertible
Do you have a service manual? My C5 manual has a procedure for manually moving the seat forward if the motor has failed.
Old Aug 6, 2022 | 08:51 AM
ClothSeats's Avatar
ClothSeats
There are some videos on YouTube that may be helpful. Just go to YouTube and search on "how to manually move a c6 corvette power seat".
Old Aug 6, 2022 | 11:27 AM
Travis1103's Avatar
Travis1103
Cruising
I tried no luck can’t believe taking a seat out is so hard
Old Aug 6, 2022 | 11:28 AM
Travis1103's Avatar
Travis1103
Cruising
no luck in my service manual thanks though
Old Aug 6, 2022 | 12:04 PM
airbrush1's Avatar
airbrush1
https://www.corvetteforum.com/forums...ower-seat.html
Reply #14 here seems to describe the procedure for “hot wiring” the motor to force movement
Old Aug 6, 2022 | 10:59 PM
HK770's Avatar
HK770
Hope this helps
https://www.corvetteforum.com/forums...ving-seat.html
Old Aug 7, 2022 | 10:40 AM
PCMusicGuy's Avatar
PCMusicGuy
Your only non-destructive hope is to access the wiring connectors under the seat, and then provide 12v directly to the pins going to the seat motor front/back. That is what I did and it was a major PITA because my seat is always all the way back and down and my hands are not small.
To Remove C6 driver seat NEED HELP Please
