Big Brake Swap
Old Aug 25, 2022 | 07:23 PM
jsbwac's Avatar
jsbwac
Default Big Brake Swap
I know there are posts already, but I am hoping for some advice.
I have an 05 track car. Only thing still stock are the Z51brakes. I run the stock drilled rotors, calipers, with dtc70/60 pads.
I am looking to upgrade.
First thought is to upgrade to Z06 six piston fronts and 4 piston rears. Would this bolt right up? Then I am thinking to move to Wilwood or similar, but they aren't cheap.
Is the swap a big deal? I saw Wilwood says with the Z51 rotors I coukd bolt on their 6 piston fronts.
Any information is appreciated.
Old Aug 26, 2022 | 09:33 AM
sccaGT1racer's Avatar
sccaGT1racer
Dont waste your money. Get the ap setup from essex and be done.
Old Aug 30, 2022 | 05:31 PM
James Heracious's Avatar
James Heracious
The brakes will bolt up. The problem is wheel to caliper clearance.
Old Aug 30, 2022 | 10:01 PM
Keppler's Avatar
Keppler
St. Jude Donor '25-'26
Don't waste your money. Get the ap setup from Essex and be done.
I did this with the Radi-Cal CP9660 with the 372mm rotor diameter. The spacer needed was 10mm for the GM stock chrome wheels. The kit bolted on with no issue.
They are very pricy but the performance was absolutely perfect. If you run up to 160mph you want to hit the brakes without fail every time. I ran stock rear brakes with racing pads.
I can sell these when I am finished with HPDE and recoup much of what I paid.
To Big Brake Swap
