Red or Blue Locktite
Old Aug 26, 2022 | 03:37 PM
New Vette Man's Avatar
New Vette Man
Default Red or Blue Locktite
Going to replace the axel nuts. Bought the Dorman axel nut but what about the Locktite, red or blue? I’m leaning towards the red because that is more permanent. Why replace you say, just peace of mind I guess. It’s on a 07 Z51
Old Aug 26, 2022 | 03:52 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
272 Loctite is recommended. 271 Loctite is also red, but is for smaller fasteners.
Old Aug 26, 2022 | 07:50 PM
farmington's Avatar
farmington
Use the red. Your old nut can also be used as a lock nut.
Old Aug 26, 2022 | 10:12 PM
bwill03z's Avatar
bwill03z
I think most ppl use the red 272 Loctite and you can use the old nut as a lock nut also but that might be excessive if you use the Loctite. Be careful not to over torque the nut.
Old Aug 29, 2022 | 03:35 PM
New Vette Man
I know this has been beat to death on this forum but what is the proper torque? I’ve heard 118 ft lbs to 160ft lbs. I want a definite answer!
Remember this torque is for a old axel,which has already been torqued once, not a new one.
Old Aug 29, 2022 | 08:19 PM
bwill03z's Avatar
bwill03z
Yeah there’s a lot of debate on torque and the spec has been changed over the years. If you’re going to use Loctite torque to 140ft lbs and you’ll be good to go.
Old Sep 1, 2022 | 01:54 PM
Orion2011's Avatar
Orion2011
Red requires a torch to ever loosen. There is Orange with is supposed to be as strong as red but can be loosened with hand tools.
Old Sep 9, 2022 | 01:58 PM
New Vette Man
Well today I checked the axel nuts. The passenger side was loose, I couldn’t turn it without the socket but it spun off with no effort. Driver side was tight. I took both off and replaced with new Dorman axel nuts 34 mm. Used Locktite 271 instead of 272. Torqued to 140lbs. I’m done thinking about it.
Thanks to everyone who responded!
update, now that I finished the wheel nuts and new rear sway bar links about a couple months back, no noise coming from the rear at all. It must of been that rear pass. wheel nut that was causing the noise. Easy job!
To Red or Blue Locktite
