Heat related voltage drop
Old Sep 2, 2022 | 08:31 PM
Vette_Beach's Avatar
Vette_Beach
Default Heat related voltage drop
2006 Z51 convertible, 105000 miles
How do I diagnose the radiator fan controller? When the engine is up to temp and I'm in traffic the externally connected VOM drops to 13.1 volts. The DIC shows 12.4 volts.
I have checked continuity and resistance on every wire I can reach and all checkout. I have a new starter, battery and alternator. Appearing to be a heat related problem, the temp controls are my next target.
Any suggestions or recommendations appreciated?
Old Sep 3, 2022 | 09:50 AM
pcguy2u's Avatar
pcguy2u
Need a more robust description of what the issue is. What is causing you to look at this? Are the fans not working, or? 13.1 doesn't seem to be a "drop" and where is the VOM connected???
Nick
Old Sep 3, 2022 | 06:34 PM
jonjoy's Avatar
jonjoy
when the fans come on the voltage is going to drop, the amount of that depends on engine RPM. the big 3 kit from Sac City Corvettes is a definite improvement
Old Sep 4, 2022 | 06:10 PM
Vette_Beach
I had the VOM connected to the battery hot post and the neg on a chassis ground. Thats how I got the two numbers. I got the "check charging system" warning awhile back so I replaced the starter, the battery and the alternator.
Out on the road I see 13.9 to 14+ on the DIC but when in traffic it gradually goes down to less than 13 into the 12-volt range. My understanding is it should never go below 13.5. The engine temp is always normal.
I would not be chasing this problem if I had not got the service charging system warning. For now, I'll wait for something to stop working so I can pinpoint the issue. The DIC is not reading correctly. It is 0.3 volts lower than the VOM. I'm going to add 0.3 to whatever the display is and move on.
Old Sep 4, 2022 | 06:57 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
The .3 volt difference is normal…this is the number on my C5. DVOM is reading battery voltage.You should do a voltage drop test on the B+ side of the charging system with DVOM…one test lead on alternator B+ and other lead on battery B+…you should see more than 0.3 volts…and that’s right both leads are on positive at the same time…negative too…to check negative side one lead on alternator case and other lead on battery negative terminal…not more than 0.1-0.2 volts. This is done with an electrical load on the electrical system…Alternator B+ cable goes to starter solenoid and battery B+ goes there too…make sure connection at solenoid is tight and no corrosion…if alternator is charging but battery is not that is usually the place it happens. Continuity and resistance is NOT the way to check these circuits…voltage drop is !!
To Heat related voltage drop
