Help identifying this part, can it be fixed?
Old Sep 10, 2022 | 04:28 PM
SivaSuryaKshatriya's Avatar
SivaSuryaKshatriya
Default Help identifying this part, can it be fixed?
Hi, the engine out of my C6Z is out right now as we prepare to put a new motor in.
While it was out, I noticed that there is a hole in some of the fiberglass near the driver's side.
1) Does anyone know the part number? I know it's related to the driver's side fender liner, perhaps inner wheel housing, but I need to be sure.
2) It looks like something that can be patched up with some fiberglass fairly easily; am I correct?
Old Sep 10, 2022 | 04:35 PM
davidfarmer's Avatar
davidfarmer
Are you talking about where the coolant reservoir bolt was? Looks like it pulled out maybe? You can glass a new stud in, you don’t see it with the reservoir in place
Old Sep 10, 2022 | 04:56 PM
SivaSuryaKshatriya
Yes that's the spot. Glad to hear it's a fairly simple fix.
Now I just wonder how it happened in the first place.
Old Sep 10, 2022 | 05:45 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
You more than likely broke it when you removed the coolant reservoir
Old Sep 11, 2022 | 12:40 PM
Corvette_Dez's Avatar
Corvette_Dez
... Now I just wonder how it happened in the first place.
I would also check the skid plate/radiator support to make sure it hasn't broken loose from its mounting bolts. It's a very common problem on the C6. It can cause a lot of movement when it does.
Old Sep 11, 2022 | 05:08 PM
SivaSuryaKshatriya
That was it! Shortly before the rebuild, the front of my car was dropped onto a rumble strip when I went off-track, which is partially why I'm here with the motor out.
I checked the radiator support and it needs to be replaced... good looking out.
To Help identifying this part, can it be fixed?
