Which injector do I need? 50# flex
Old Sep 11, 2022 | 02:33 PM
i3oosted's Avatar
i3oosted
Default Which injector do I need? 50# flex
Using a 50lb injector for flex fuel, standard fuel rails and intake.
I see 2 different ones
https://www.michiganmotorsports.com/...3-5-7-6-0-6-2/
38mm oring to oring
https://www.michiganmotorsports.com/...tors-set-of-8/
46mm oring to oring
Old Sep 14, 2022 | 12:29 PM
speedycpu's Avatar
speedycpu
If it is for an LS3, looks like 34mm is the way to go (not center to center, per Injector Dynamics comparisons). To try to compare, when I went to ID1050X injectors for my LS3, I got part number 1050.34.14.15.8. They have some dimensions on this page that may help: http://injectordynamics.com/injectors/id1050-xds/ They don't list center to center in the drawings, just the bottom of the O-rings. Center to center may be something like 36mm in that case.
If it is for an LS2, they list 48mm instead of 34mm. If you want, I can measure the center to center O-ring height when I get back home from some DW 55lb injectors I took out of the LS3 for reference.
Old Sep 14, 2022 | 04:34 PM
i3oosted's Avatar
i3oosted
I wasnt sure if it was the 34mm or the 48mm ones. I have the LS3 so its the 34mm. I bought a set from DSX, thank you!
Old Sep 18, 2022 | 09:24 PM
jonjoy's Avatar
jonjoy
injector connection in Atlanta Ga
To Which injector do I need? 50# flex
