Transmission service.
Old Sep 14, 2022 | 02:53 PM
Whatscooking's Avatar
Whatscooking
Default Transmission service.
When you take the pan off and replace the filter then add 7 quarts should you drive the car to make sure the air has been purged or can it be done while on the lift, I have read about bringing the temp up to 100 then pulling the plug to set the level but want to be sure on the run time.
Old Sep 16, 2022 | 09:57 AM
RetroGuy's Avatar
RetroGuy
Search this on YouTube for your exact Vette/ trans. Plenty of info out there.
Old Sep 16, 2022 | 10:10 AM
Whatscooking
There is lots of good info to be found especially here on the transmissiin service. I should of asked instead for opinions on adding what has been recommended to fill up to a quart extra then warm up to temp then drain out the excess while running. The track guys say to put a extra quart in to help with launching.
I just thought it would be a good idea to go drive it if nothing else to mix well with the old oil left to get some more crud out when i drain the excess.
Since i have drained the coolant out and refilled with distilled water to get a flush i thought it would be a good time for a short drive then drain them both.
To Transmission service.
