like the title says my disc is saying read error or asks me to insert disc after the disc is already
inserted.
everything else seems to function normally.
I am able to access the radio controls.
Local Chev. mechanic says the disc reader is ng.
looking for advice,
do I replace
the unit
The car is an 08 coupe.I would prefer to keep the car original
Might just be a dirty optical read head in the unit. Get a can of compressed air & remove the disk, then use the included tube to insert into the unit door and blow out the dust/dirt that may be collected inside and on the read head. See if this resolves the problem first.
You might get lucky and reset the player with a disconnect/reconnect of the battery. If not and you want to stay with a stock unit, there are plenty available from members upgrading their units, but you will need access to a Tech2 or Nano to sync the procured stock unit to your VIN to get past the anti-theft mode.
