Program after Header install
Old Oct 17, 2022 | 07:55 PM
1320#me's Avatar
1320#me
Default Program after Header install
I bought a set of Hooker Headers from Summit Racing that were delivered today. I called a shop to have a quote on installing them which I knew would not be cheap and they wanted 450$ to program it after the installation. Iam okay on the quote they gave me but thought this program price was a bit high. If this is what it is then I am okay with it but wanted to see what others that have had this done thought. Thanks.
Old Oct 17, 2022 | 08:36 PM
SixAddict's Avatar
SixAddict
My tune was $550. Without header install.
Old Oct 17, 2022 | 08:43 PM
1320#me's Avatar
1320#me
The 450 was after header install. I should have been more clear. Thanks.
Old Oct 17, 2022 | 09:42 PM
SixAddict's Avatar
SixAddict
No worries, that’s what I thought.
Then after that tune and header install, I had a cam put in an that was another $550. Go figure, I wasn’t real happy about that but…..
Old Oct 17, 2022 | 09:59 PM
bwill03z's Avatar
bwill03z
Yeah you will want to let them tune it after they install the headers, and $450 is a good/fair price for a tune assuming it’s a dyno tune. Most places charge at least $500 for just a tune.
Old Oct 17, 2022 | 10:20 PM
Matt Zed's Avatar
Matt Zed
If they're just turning off the rear o2 sensors then that is a no go for $450 and you need to go somewhere else, BUT if they are recalibrating your maf curve to adjust fueling, then that is a good price.
Believe it or not, some places have charged $450 just to disable 4 codes, that is NOT TUNING, it's 2 minutes worth of work at a cost of $150 in credits.
Old Oct 18, 2022 | 08:02 AM
blownbayou's Avatar
blownbayou
My tune session (dyno and road) was $700... Well worth it. Car runs like a champ and the numbers are not too shabby for A6 and NO BOLT ONS!!!!! (see sig)
Old Oct 18, 2022 | 10:59 AM
VetteVinnie's Avatar
VetteVinnie
Something to bear in mind are the sensors ready. Are you in an area that requires you to pass emissions? I know in Harris County, TX, you can't have more than one sensor in the "not ready" state, and to get it there requires a tuner who knows what they're doing. I went through this on two previous Corvettes (my 2008 Z06 and my 2010 ZR1). There's a tuning trick to bypass the conditional testing and just force them "ready".
Old Oct 18, 2022 | 03:50 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
That's a reasonable price.
Tom
Old Oct 18, 2022 | 05:04 PM
1320#me's Avatar
1320#me
No emissions and the shop I am going to is the real deal. Thanks for all of the input.
Old Oct 21, 2022 | 05:57 PM
jonjoy's Avatar
jonjoy
a good shop like Vengeance Racing will "retune" for a smaller fee as you mod.
Old Oct 21, 2022 | 08:32 PM
Dano523's Avatar
Dano523
As stated, need to make sure that the after install price, is to tune as well.
Hence with long tube headers, the post cat O2 sensors are not used, so you have to go into the tune to turn then off.
Next, is since the long tube headers make the motor gain more power by increasing the amount of exhaust that is pulled from the heads,
The tune has to be redone to keep the engine from running too lean during WOT (when the system is running open loop).
Old Oct 22, 2022 | 11:48 AM
Matt Zed's Avatar
Matt Zed
You wont know theyre the real deal until someone else scans your tune, you'd be surprised how many praise shops that turn out to be hacks when someone skilled looks into their work. Not saying this shop is like that but you need further investigating before you can fully trust a shop to say they did everything perfectly.
Old Oct 24, 2022 | 07:36 PM
1320#me's Avatar
1320#me
The shop I am dealing with is the kind of shop you would bring your car to see if the other guys were hacks. Thanks for your input.
Old Nov 13, 2022 | 12:26 PM
MSGT-R's Avatar
MSGT-R
Thanks for all the info. I live in a non smog-test county, and this mod is in my future if I make changes to the exhaust. Good to know that the old in-line resistor to the O2 is no longer done.
Great forum!
Old Nov 13, 2022 | 12:53 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
And if the tuner does lots of tunes, he more than likely has an 'unlimited' HP Tuners account, so he don't pay the extra credits for every car he gets in for tuning.
To Program after Header install
