I'm not expert on the Eagle eyes have set on my Corvette, and here is what I learned since it doesn't come with instructions.
First there numbered for position it could be A & B, which is A is outside lights and B inside, might have numbers 1&2 same thing 1 outside light.
Second, check your connections cause when you connect the wires backwards, they can go either way, so make sure you connect back wire from the car to black wire to light, if you do it wrong nothing will work properly.
