Battery Replacement
Old Oct 29, 2022 | 02:16 PM
Maz615's Avatar
Maz615
Default Battery Replacement
Hey guy's can i get a few suggestions on a new battery for a 2012 CE GS...Thanks in advance !
Old Oct 29, 2022 | 04:01 PM
C6VetteLover's Avatar
C6VetteLover
AC Delco Or Interstate
Old Oct 29, 2022 | 05:13 PM
Ryanvar42's Avatar
Ryanvar42
They’re all fine.
Old Oct 30, 2022 | 01:19 AM
gdmoore01's Avatar
gdmoore01
I purchased the Duracell AGM group size 35/85 from Sams Club for my 2013 GS and it fit perfectly. Also, the cutouts for the terminals were not so tall as to inhibit the cable connections...GD
Old Oct 30, 2022 | 10:08 AM
RetroGuy's Avatar
RetroGuy
Optima RedTop, A bit more $$ but worth it in my opinion...
https://www.optimabatteries.com/products/redtop/
Old Oct 30, 2022 | 11:28 AM
BadAV's Avatar
BadAV
This is what I put in my Centennial. Two years without issue. The OEM battery lasted 8 years before it gave up the ghost, so it had a good run.
Not a fan of Optima since manufacturing was moved offshore. I had 2 bad Red Tops in a row.
Old Oct 30, 2022 | 01:30 PM
Dano523's Avatar
Dano523
Yep. Duracell Agm from Sams for around $100 fits the bill nicely.
You can spend about twice the amount for another brand battery and maybe get another year out of it, but since the batteries are so easy to replace once they do start having problems, why?
Just make sure that the battery tender you are using for the car, is rated for AGM batteries.
As for Optima batteries, that ship sailed a long time ago when they where bought out, and now just produced abroad like every other battery.
Old Nov 1, 2022 | 02:41 AM
GettnBetter's Avatar
GettnBetter
Odyssey Extreme is best in industry, metal shell, brass terminals and virgin lead construction. Pulse amps that you can hear every time the starter engages and the lowest internal resistance period. Anything else is just a battery. Then again, any old wet cell does work for a lot less.
Old Nov 1, 2022 | 08:11 AM
Blackship's Avatar
Blackship
2025 C6 of the Year Finalist - Modified
Have the Varta LA60 which is something like the yellow Optima but less expensive (in Europe).
To Battery Replacement
