2008 Convert Ign Issue
Old Oct 30, 2022 | 04:45 PM
awschucks's Avatar
awschucks
Default 2008 Convert Ign Issue
Before I drill a 6" hole in my trunk to get to the door opener, does anyone know if a slim jim will work to open the door. I was hooking up the winter trickle charger and the hood slammed down. Took out my key to open things up and there is some bondo in the key way on the trunk opener and thus could not get the key. noe what?
Old Oct 30, 2022 | 04:50 PM
jonjoy's Avatar
jonjoy
jack the car up in front and you can attach the charger at the starter
Old Oct 30, 2022 | 05:46 PM
awschucks's Avatar
awschucks
Wow that was easy....This forum continues to amaze me. YOU saved me from drilling a hole in my trunk.....Thank you thank you thank you
Old Nov 2, 2022 | 10:25 AM
jonjoy's Avatar
jonjoy
If the battery's dead a trickle charger does little and is bad for your battery. Look at the 5 amp Deltran, been using one for years,
To 2008 Convert Ign Issue
