Valve Cover/PCV Question
Thanks for the help!!
Rob
I have some concerns though
1. There does not appear to be much baffle in the valve cover leading to the hose, it may aspirate oil vapors or even liquids. I would watch or check the hose for oil liquid after using for a while.
2. The hose is kind of small and long, it may not provide adequate PCV pressure drop for wide open throttle. I recommend you MEASURE the crankcase pressure at WOT using a 1-bar map sensor to ensure there is some pressure drop near the valve cover. If you need a video I have a how-to-diy
If you could send me the how to video that would be appreciated. I plan on running a -6 line which is 3/8 ID, The cover has a 1/4 pipe port on it, I could go up to a -8 line if you think it would need a larger line would be beneficial (even tho I am limited to the 1/4 pipe port)
Small lines increase friction so you don't want very small either.
Main thing is short as possible. That is why I like the line near the passenger valve cover to air intake pipe, very close by.
A happy medium, you can trial and error to find ideal pressure drop by managing line diameter and air filter. The air filter provides the suction at WOT to the crankcase. The filter is rated some CFM @ pressure drop for example 500CFM @ 1.5" Hg for a random air filter. If the engine flows 500CFM then it will apply 1.5" Hg to the crankcase tube, which means < 1.5" on the crankcase since energy is lost between the tube and crankcase.
I shoot for 1.5" to 3" Hg in wet sump applications. Here is my video. Its turbo but the same thing you can do where the PCV hose attached to crankcase, monitor using map sensor.
A tenth of a volt of pressure drop on 1-bar map is around .325PSI or so, or .66" Hg.
As a general rule no less than 0.5" Hg is adequate. 0.5" to 1.5" Hg is standard for all engines from all OEM, wet sump, made before 2012~ After which many engines run even more vacuum. I prefer 2 to 3" Hg for performance engine for improved oil cleanliness, increased oil scavenging, reduced oil leaking.
