Service charging system error after changing coils
Old Nov 21, 2022 | 08:23 PM
racerx3317's Avatar
racerx3317
Checked the under hood fuses. Checked out ok. I’ll check the footwell fuses when it’s not freezing out by me. I’m guessing I’ll get a bit of draw from my M2W which is wired to stay in whatever position I left it and the interior lights that I changed to LEDs. I also just took the fuse out if my aftermarket speakers/amp to check if maybe that was draining the battery overnight. Battery was at 12.50 just now. Left it off the charger. Will check tomorrow and report back.
Old Nov 21, 2022 | 09:48 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Most likely your LED’s that you’ve changed out can cause a parasitic drain…happens to some members here after doing that.
Old Nov 21, 2022 | 09:51 PM
racerx3317's Avatar
racerx3317
It possible. They’ve been in there a couple years, though. Hasn’t been an issue till now. I’ll probably switch them out anyway. I’ll let you know what I find.
Old Dec 4, 2022 | 08:06 PM
racerx3317's Avatar
racerx3317
Quick update. I swapped out the interior LEDs to auxito error free. That alone was a game changer, no more FOB errors. I also removed a front camera I had installed that had a button with a light that stayed on and I rewired my M2W to zero drain. Seems much better but I’m still sure not its fixed. Last night I shut the car down and it was 12.85. This am it tested at 12.74. Much better and fired right up. What was weird was that i had it on the Ctek charger pretty much all last week. I tested the voltage daily but I didn’t start the car until yesterday. The battery tested at 13.86 on Friday night before I started it on Saturday am. I got a brief service charging system on the DIC which quickly went away. No error when i started it today. Maybe the voltage was too high? It’s much better but I think I’m going to check every relay one by one. How much voltage drop is considered normal overnight if nothing is draining the battery? Thanks for your help
Old Dec 4, 2022 | 08:09 PM
C5 Diag's Avatar
C5 Diag
Did you perform a parasitic drain test with your DVOM or check the drain with the AMP setting of your DVOM ??
Old Dec 4, 2022 | 08:46 PM
racerx3317's Avatar
racerx3317
I checked the under hood fuses for drain with the dvom and they tested ok. Didn’t do the footwell fuse box yet as I cant figure out the best way the reach down there without opening the door. I changed out what I suspected was causing a parasitic drain.
Old Dec 4, 2022 | 08:49 PM
C5 Diag's Avatar
C5 Diag
Latch the door with a screwdriver as outlined in the video I posted…then you can check the IP fusebox.
Old Dec 4, 2022 | 09:13 PM
racerx3317's Avatar
racerx3317
Got it. I didn’t think you could do that with the electric locks on the vette.
Old Dec 6, 2022 | 08:31 AM
Petera90's Avatar
Petera90
https://www.corvetteforum.com/forums...error-msg.html
https://www.corvetteforum.com/forums...intenance.html
Pull the door buttons and open them up. If you have corrosion. Then you have corrosion at connectors as well.
Old Dec 10, 2022 | 03:13 PM
racerx3317's Avatar
racerx3317
Just checked all the fuses for drain. All came back normal. I’ll have a look at the door buttons. The search continues.
Old Jan 29, 2023 | 05:36 PM
racerx3317's Avatar
racerx3317
Well, I think I might have sorted the issues out. I had a suspicion that my el cheap o alternator was at the very least part of my issue. I found a mechman on here and it cured most of the issue. While I was at it I did a powermaster starter. I’m glad I did, even though the installed kick my butt a bit. Hot start issue seems to be gone. I found one of the studs was a bit loose on the old one. Thanks to everyone for the assistance.
