08 corvette
Old Nov 11, 2022 | 08:28 PM
dave08's Avatar
dave08
2nd Gear
Default 08 corvette
NPP exhaust baffles do not close, fuse has been replaced, anyone ever have this problem?
Old Nov 12, 2022 | 08:41 AM
ApexClone's Avatar
ApexClone
There's a controller mounted in the hatch. See here for pics: https://www.corvetteforum.com/forums...is-module.html
They do go bad from what I've seen. I'd check for power there.
Also check your vacuum lines and make sure they aren't disconnected or have a leak.
Old Nov 26, 2022 | 01:37 AM
Conchie13215's Avatar
Conchie13215
I had this problem this year. The Npp controller was not the issue. I replaced the vacuum valve in the rear of the car. GM part number 25794610.
I removed 2 of the rear tail lights and was able to reach down and unscrew the valve. Removed 2 small hoses and reattached to new valve. Valve is about 2-3 inches long and black in color.
Simple fix.
To 08 corvette
