Z06 Crank No Start
I checked all fuses.
I can jumper the fuel pump where the relay is and hear it run.
After reading multiple threads I concluded it was probably the crank position sensor.
I replaced it but still will crank but not fire.
So i bought a tech2 clone.
I can see the crank position sensor voltage and also see that it read counts when cranking it.
However when trying to read the fuel pump control module data, I get no communication. Also get the same communication error when trying to command the fuel pump.
I did a continuity test on pins 6 and 14 on the OBD2 connector and got 65 OHMS, which I believe is good.
There are no codes.
Is the fuel pump control module bad? That is that part of the fuel pump assembly, correct?
Is there anything else I should be looking at?
Thanks for any help.
You are aware that if you install a new crankshaft position sensor, you must perform a crankshaft position sensor relearn procedure, right?
There are no codes.
One of the reasons I bought the Tech2 was to do a crank position relearn, but I cant do that until its running.
IIRC, the engine will not crank if there is no pressure and it will try to run the pump for 10 seconds before giving up... I think that's the way it works. Someone will correct me I'm sure...
So if there is pressure, you can probably assume that it's the correct amount of pressure.
Nick
Nick
"The CAN Bus circuit starts with the ECM, the circuit passes thru the EBCM (ABS controller), then to the fuel pump control module, then to the BCM." Is what i read.
Fuel pressure is good at the fuel rail. So I don't think its a fuel issue at this point.
How do I check the coil side of the relay? I don't have a test light but do have a multimeter.
On to the CKP. The tach does not move when cranking.
The Tech2 shows under ignition data:
5 volt reference 1: 5.0 Volts
5 volt reference 2: 5.0 Volts
5 volt reference 1 Circ OK
5 volt reference 2 Circ OK
CKP sensor 252 RPM when cranking
What are my next steps?
Thanks for all of your help!!
Now to check CKP...you saw RPM at 252 which leads me in the direction that the CKP is good but let's check injector pulse and spark to make certain it's good or not. Remove a plug wire off the coil pack and keep it about 1/4 inch away...now crank the car and see if you have spark...if NO spark we will now check for injector pulse...remove the connector off an easy injector to access and now connect test light to B+...now touch test light to ground and make sure it lights...the injectors have 2 wires...a power wire (12 volts) and control...the ECM will ground that control wire so that is why we hook test light to B+...the control wire is a striped wire so as you crank the engine over the test light will blink when you touch the tip of the test light to that striped wire...if no spark or injector pulse the CKP is likely bad...I don't know how that Racetronix is wired but that may be suspect if that's when all your troubles started...what brand sensor did you use...I hope not Dorman if it was aftermarket !!...also if you have a fuel pressure gauge if CKP is bad the pump will show pressure for 2 seconds but as the engine continues to crank the fuel pressure will decrease...the ECM uses ignition reference signals from the ECM to keep that control side feed E7 energized...there is a "bypass test" at the CKP sensor or at the ECM that can be used to fire the plugs, energize the injector control and run the fuel pump....so no trouble codes for fuel pump circuit or CKP ???
https://youtu.be/McnXLcJNVfI
The CKP is a Carquest brand. No one had an AC Delco in stock. I had to order the AC Delco CKP and now have it just in case.
The fuel pump is https://www.racetronix.biz/k/fuel-pu...-e85/tu475-450 with the upgraded FPWH-008 and IPH-008 wiring harness installed 2 years ago.
I will need to get a test light and run the the other tests.
Thanks again for all of your help.
This morning was the first chance I had to do some testing. I decided to test the injector voltage and pulse first, so i disconnect the injector plug from from #2 cylinder. I have voltage to the injector with the ignition on. I then have my wife get in and crank it while i check injector pulse. It starts right up!! I had her shut it off, reconnected the injector plug and it started right up again.
I think it likes her butt in the seat better than mine, lol.
I made no changes, so I would assume that I need to check all of the grounds on the harness and also check for opens and shorts.
I am going to check injector circuit, coil circuit and CKP circuit.
ALSO remember your car is 13 YO I have seen this many times on older cars that the Anti Theft system will create a No Start---
If you have access to a tuner try to turn the THEFT system OFF--
Another issue is that the KEY gets worn out from years of use--The key has an OHM pill hidden in the BASE and gets worn and sends the wrong OHM reading TRY to use your spare key to see if it works
