Oil leak after cam install
Old Dec 4, 2022 | 04:53 PM
GlennyW's Avatar
GlennyW
Navigator
Default Oil leak after cam install
I recently put a cam in my ‘13 grand sport and I just noticed today that there is a tiny bit of oil coming from my crank seal. I didnt have the alignment tool for the cover but i fitted the HB to technically “align” it before torquing the cover bolts down. I tightened the bottom 2 pan bolts first and then the rest of the bolts in a side to side sequence. When i went to check the bolts again after driving the car, i noticed the 2 bottom bolts werent as tight as the others so i just gave them a good snug and they tightened up. Ran the car for 30 minutes and didnt see anymore oil coming from the seal but I am worried ive already damaged the new seal. Is it possible that tightening those bottom 2 bolts where the pan meets the timing cover corrected my issue? Or am I going to have to start looking for time to pull this timing cover back off?
Old Dec 4, 2022 | 09:35 PM
russ472's Avatar
russ472
ran into the same issue when I did my cam. it took out my front seal. go ahead and bite the bullet and get the alignment tool and new seal.
Old Dec 4, 2022 | 10:46 PM
GlennyW's Avatar
GlennyW
Navigator
did you catch the leak right away? Ive put 10 miles on the car just for that very reason to make sure nothing was leaking and sure enough…
Old Dec 5, 2022 | 12:32 PM
El_Steveo's Avatar
El_Steveo
It would appear the front main seal got damaged on install. the alignment tool is important.
Old Dec 5, 2022 | 06:32 PM
russ472's Avatar
russ472
i drove it to and from work (40 miles round trip) and could smell oil when i got it home.
Old Dec 5, 2022 | 06:36 PM
DougHG8's Avatar
DougHG8
It sounds like you pressed the HB on the crankshaft with the front cover loose; is that right? Used sealant at the corners where the cover, pan and block meet? I think my only concern would be that if the cover was forward of the rubber part of the oil pan gasket, you could scrape it off as the cover goes back flush with the block, but I guess you can see it's leaking around the seal. I don't have an alignment tool but work on LS engines a lot. I set the side-side clearance between the seal and the crank using whatever is handy to measure the gap to make sure it's even on both sides and never have trouble. That way I tighten the front cover completely before pressing the balancer on.
Old Dec 5, 2022 | 06:44 PM
Kingtal0n's Avatar
Kingtal0n
I did my front seal the same way- without an alignment tool. I have 20,000 miles on the cam and notice some bit of oil residue slinging around the seal area.
Apparently the alignment tool is worth its weight. I went ahead and ordered the saccity corvette alignment tool - nice metal, not 3D printed or plastic. I got front and rear and the oil barbell too. I'll live with the tiny residue for now, wipe it up every 10 or 20k or whatever. But next time the engine has to come out for any reason- I'll be ready. $.02
Old Dec 5, 2022 | 07:00 PM
GlennyW's Avatar
GlennyW
Navigator
i pressed the balancer on with the cover seated finger tight, put a bead of silicone on the corners of the cover and tightened the cover down. Got the car back together and drove the car 10 miles and noticed 2 small drops on the ground the next day. Double checked all of the bolts on the oil pan and checked the two below the cover and those two were not snug enough. Snugged them down and drove the car tonight. No oil on the ground and no oil around the seal. I think were good to go… fingers crossed
Old Dec 5, 2022 | 07:04 PM
GlennyW's Avatar
GlennyW
Navigator
I definitely smelled oil burning on my first drive and figured it was residual from loosening the pan. After snugging those two lower bolts down last night, i dont smell anything and everything is still dry. Hopefully i walked away a lucky man from having to tear it back down again. Ill continue to watch it and will update everyone. Thank you all for your help!
Old Dec 6, 2022 | 09:52 AM
DougHG8's Avatar
DougHG8
Sounds like you're good to go! You probably had a bit of a leak between the front cover and pan in that case rather than the crank seal.
Old Dec 6, 2022 | 10:08 AM
666lisa's Avatar
666lisa
Oil pan bolts always last.
Old Dec 6, 2022 | 12:44 PM
grinder11's Avatar
grinder11
I haven't used the tool, but have centered the cover w/o the seal in place, using adjustable parallels. Anyway, I'll get the Sac City tool next time. I've never understood why GM didnt dowel the covers. Well, I guess I do-$$$$!! Keep in mind the only alignment that needs to be correct is horizontal plane, because the cover must stop, and self align in the vertical plane against the pan gasket aluminum. I placed some Hi Temp black RTV on the bottom of the cover, and a skin coating on the aluminum of the pan gasket, snugged my cover perimeter bolts hand tight, then snugged the 2 pan bolts hand tight. Then torqued the cover bolts, and then the pan bolts. Its worked for me. Just be sure to thoroughly clean all the old RTV from the pan gasket and cover bottom. This method should work for most, but I guarantee only the first 10 seconds, or 10 feet, whichever.......
Old Dec 6, 2022 | 08:32 PM
furious427's Avatar
furious427
Always use the alignment tool, way too much work to get it wrong.
Old Dec 6, 2022 | 08:57 PM
ClothSeats's Avatar
ClothSeats
The alignment tool not only helps with alignment of the cover, it also can be used to install the seal nice and squarely.
Old Dec 10, 2022 | 10:36 PM
GlennyW's Avatar
GlennyW
Navigator
Just an update… crank seal is ok. After brake cleaning everything, I drove it until oil got to 160* and when I inspected it, the oil is leaking from the oil pan gasket. I put a bead of rtv on the corners of the pan gasket where it meets the timing cover but nowhere else. Is it possible I needed to put a bead across the front as well?
Old Dec 11, 2022 | 12:16 AM
DougHG8's Avatar
DougHG8
No, the front of the oil pan gasket has a rubber seal on it so it should seal the front cover fine there. I only put sealant and the two corners; I place the front cover gasket into the sealant so that it gets some on the back and front of the gasket as it goes on. I've never had one leak. Did you do the walk on of the cover method? You tighten the front lower bolts to pull the cover up to the block, loosen, then tighten the two bolts under the pan, pulling the cover down to the pan, loosen them, then repeat. This pulls the cover into the corner and makes for a good seal. I always tighten the pan bolts first as the final pass but that's after I've checked the side to side clearance of the front seal to the crankshaft to make sure the spacing is even.
Old Dec 11, 2022 | 06:50 PM
GlennyW's Avatar
GlennyW
Navigator
i did that exactly how you did it. Went back and made sure everything was in torque spec. Ill go back and brake clean everything again and let the car get up to temperature to see where exactly its coming from. Ive ruled out the crank seal being that its bone dry. Its either right at the front behind the lower part of the balancer or its coming from the corners where i put a bead of rtv on
Old Dec 12, 2022 | 03:23 PM
Kingtal0n's Avatar
Kingtal0n
The corners are tricky because oil can leak down from behind the seal while the permatex is setting up.
I recommend clean it with brake cleaner, use a razor blade to make sure the mating surface of metal is fully clean and cleared and dry.
Then, let it sit in the air for 5 or 10 minutes and feel around for oil residue that has leaked into the area you intend to seal.
It may help to let the engine sit for a day or two before beginning the procedure or once the cover is removed to let the oil stop seeping.
To Oil leak after cam install
