So figured I'd as a quick question. At what point would the BTR Trinity make sense on an N/A LS3 setup. I see that its intended to as BTR put it "bridge the gap between N/A and Boosted applications". The intake is pretty decent looking but I wouldn't want to sacrifice performance or drivability to have a cool looking intake. Is this something that could see gains for a mild cam only build or is it more intended for all out heads cam fast spinning builds. I see the Optimum range is 6000-8500, I dont typically spin mine much above 6200 so I'm not sure I'd see much benefit. If I could see some sort of gain out of it I'd be all in but my setup is a pretty mild cam only (BTR stage 2) otherwise stock LS3 (full exhaust/headers). Would love to hear some thoughts on it.
For stock cubes with a mild cam, I'd lean more towards a ported and rod modded stock LS3 intake manifold. That's what I'm using along with CNC ported and milled heads along with a few other goodies. Also running a milder can that what you're considering. Decent fuel eco along with perfect manners. 500/454 at the wheels.
While the Trinity wasn't tested, I'd bet it would slot in there with some of those other max effort type intake manifolds. On a stock cubed, mild cammed LS3, you'd lose power in an RPM range you actually use and never see the increases these manifolds promise because you don't rev your LS3 that high. I can see these higher end intake manifolds being right at home on a stroked 416 LS3 with killer heads, big cam, 2" headers, and 7500 rpm capable valve train. I love reading about those bad girls, but have no desire to try to live with one
Kinda my thoughts as well, Rod mod is where I'm currently leaning. Figured never hurts to ask though. I'd hate to loose down low power band because the car lives there most of the time. I want to keep it autocross/track day happy.
That intake has very short runners which is why the rpm range is so high. You'd def lose power and torque in your usable rpm range.
Plus the heat soak compared to a composite manifold.
The stock LS3 intake mani isn't horrible as is. When I put my LS3 together four years ago, it was pretty much ported/rod modded LS3 manifold or FAST. I looked at lots of test data and just didn't see anything that would sway me towards the FAST. I knew I'd go mild on the camshaft as I absolutely hate nasty manners in a street car. Not throwing shade at the FAST, it just didn't fit my program.
I understand that VERY little racing takes place below 4500 or 5000 rpm. I saw little or no improvement below 6000 rpm though. And below that the FAST was a little on the lazy side. Plus, the modded LS3 intake was $400 and the FAST was $900. I wasn't on a super tight budget, but didn't want to spend money that didn't show an obvious increase in power. And power = fun!
I feel same way about the Fast intakes.
I ran mid 9s NA with a 441 ls7 through a 90mm TB and stock ported intake
not exactly apples to apples but fairly close
red line is ls2 motor stock 243s and stock ls2 intake
blue is ls2 motor as cast trick flow 220s and trinity intake
what are you running for a cam? And what's your compression ratio? Edit- you must be running boost too, at nearly 800hp on the dyno
still falling off after 6, just like the stock intake, stock heads
